remote starter install
Post by gonzo4191 »
hey all, just got my remote start in the mail....http://www.pontiacbonnevilleclub.com/fo ... uff#p78242, the one there.....the CC website http://www.circuitcity.com/ccd/productD ... oid=119099
could i attempt this myself or shoudl i have CC install it??
any help appreciated, all the instructions are with it and such....
petraman
2013 Audi A4 6MT
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Re: remote starter install
Post by petraman »
Uhh, from what I've heard, they're a real pain to do... Especially if you don't have any experience with a multimeter. There's a LOT of wiring, and I think PassLock requires a bypass. But, if you still feel like you can tackle it, here's the wiring diagram:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|orange or orn/blk *1|+ |ignition harness |
| STARTER|purple or yellow |+ |ignition harness |
| IGNITION|pink |+ |ignition harness |
| SECOND IGNITION|white |+ |ignition harness |
| ACCESSORY|orange |+ |ignition harness |
| SECOND ACCESSORY|brown |+ |ignition harness |
| POWER LOCK|red/black |- |drivers door lock switch |
| POWER UNLOCK|orange/black |- |drivers door lock switch |
| LOCK MOTOR|gray | |drivers door module *2 |
| UNLOCK MOTOR|tan | |drivers door module *2 |
| DISARM DEFEAT|tan | |passenger door module *3 |
| PARKING LIGHTS +|do not use | | |
| PARKING LIGHTS -|brown/white | |DIM module *4 |
| HEADLIGHTS|white |- |DIM module *4 |
| DOOR TRIGGER|*5 |- |*5 |
| DOME SUPERVISION|gray |- |underdash light |
| TRUNK/HATCH PIN|red/black |- |RIM module *6 |
|TRNK/HTCH RELEASE|lt. blue |- |RIM module *6 |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM|lt. green |- |drivers door module *2 |
| DISARM NO UNLOCK| | | |
| TACHOMETER|purple/white | |ign. coil on top of motor |
| SPEED SENSE|dk. green/white | |cruise control module *7 |
| BRAKE WIRE|white |+ |low in drivers kick |
| HORN TRIGGER|black |- |DIM module *4 |
| WIPERS|white |+ |DIM module *4 |
| LF WINDOW UP/DN|dk. blue - brown |A |drivers door module *2 |
| RF WINDOW UP/DN|dk. blue - brown |A |passenger door module *3 |
| LR WINDOW UP/DN|dk. blue - brown |A |LR door module |
| RR WINDOW UP/DN|dk. blue - brown |A |RR door module |
| SUN RF OPN/CLOSE|dk. grn - lt. grn |A |sunroof motor *8 |
| SUN ROOF LIMIT|red |- |sunroof motor *8 |
| RADIO 12V|orange |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO ILLUMINATE|yellow/black |*9 |radio |
Notes:
NOTE: This vehicle is equipped with the pass-key III immobilizer. Use DEI part number 555G or 555U to bypass. *1 This is a low current 12V source that should not be used to drive any high current positive circuits. *2 The drivers door module is located above the speaker in the drivers door. *3 The passengers door module is located above the speaker in the passenger door. *4 The DIM module is located just in front of the blower motor near the passenger kick. It has three connectors that all exit out of the bottom of the module. *5 The drivers door trigger wire is tan at the drivers door module, and the other door triggers are dk. blue at there respective door modules. *6 The RIM module is located behind the rear seat in the upper corner on the driver side. *7 The cruise control module is located under the hood at the top center of the firewall. *8 The sunroof motor is located to the rear of the sunroof towards the top center of the rear window. *9 Power varies with the interior light volume.
Plurr
Year and Trim: 1994 SSE
Post by Plurr »
I suggest you do not try this yourself if you do not have experience with electronics and wiring. I have done alarms, remote starts, and combo kits and they can be difficult at times. I suggest professional installation because you will have a warranty and also you can have support if anything needs worked on or goes wrong. Choose your installer wisely.
1994 SSE, 180 t-stat, gucci accented interior, suede headliner, eclipse avx5000 headunit, two 7.8" sunvisor screens, two 7" headrest screens, dvd player / tv tuner, infinity kappa perfect 5.1 components, infinity 12.1 perfect in the trunk, 2 rockford fosgate 350s powers, infinity refrence 7541a, 0 gauge audiobahn high flow wiring, duralast gold battery, sound dampened trunk and doors, xenon-white headlights, 2 15" and 1 20" red neons shine on the back doors, 2 3" and 6 12" blacklights lighting up the whole interior, red leds in the vents, red optx el neon pedals, red streetglow headlight leds, clear corners, pilot seven color angel eyes, blaze seven color underlighting kit, viper 791 xv.
For how cheap it is, I'd be concerned if that unit will even work with the PASS-KEY. My AutoStart unit required an extra $100 unit to make it work with the PASS-KEY.
Plurr
Post by Plurr »
Yes they do require an extra module for passkey but you can get them online much cheaper than at an installer.
