I will fix your 2000+ radio display bulbs
- harofreak00
You may have seen the tutorial to do it yourself. If you are not comfortable doing the fix yourself, I can do it for a small fee.
You pay:
Shipping both ways = USPS Priority Mail Flat-Rate Box is $10.35 and the radio's fit perfect
Replacement bulbs from www.corvetteradios.com = $23.00
For my time = $10.00
Total costs to and from your door: $53.70
***edit*** If you want me to replace the small button bulbs, I can do that also for an additional $4.00. They are $1.79 for a 2pk, and there are 4 bulbs in the display.
You pay:
- Phyrestorm
- Year and Trim: 2001 SSEi
Re: I will fix your 2000+ radio display bulbs
Wow I hope you will continue offering this service until this happens to mine and I'll definitely send mine your way hahaha.
2001 Pontiac Bonneville SSEi // NGK Iridium Sparks - Belden MAX Wires - Silverstar ULTRA Headlights - Rebuilt Transmission and Torque Converter @ 122k - New PowerSteering Pump - New Water Pump
To do LIST: LIM and Valve Cover Gaskets, Intense Shift Kit, Intense Perf. Package 1, and GXP Strut Tower Brace
- Year and Trim: .
what about the lights in the buttons? I have a lot of those out.
- harofreak00
Nothing wrong with preventive maintenance. If you send me a radio, I can ship it back the same day I receive it.
I can do those also. Those small bulbs are $1.79 for a 2pk. If there are all out, thats 4 bulbs or $4.00
- Phyrestorm
You know I'll take up your offer and do that then, for preventative maintenance what the hell! ;) i'll be sending you a message sometime soon.
I need to fix the bulbs on my steering wheel 2 of them went out, im sure it's easy just popping them off and bam probably
- Allmachtige
- Retired Moderator
- Year and Trim: 2009 G8 GT
How much will you charge when I come up north for the next meet?
2009 G8 GT - White Hot
FMS Custom Cam, Yank 3600 SS, 1LE (ZL1) 3.91, SLP Longtubes, Magnaflow cat-back, Rotofab CAI, tuned via HPTuners
415/391
415/391
- harofreak00
You want me to do it at the meet? I'd have to bring all my stuff with.
You'd save $20 on shipping, still $23 for the bulbs and $10 for my time.
- lynn37
- SSEi Member
- Year and Trim: 2000 SSEi Dark Blue Matallic
3.4 pulley
If I find out I can't get the GXP I am trying for I will take you up on that offer. I only have the bulbs
out on the buttons for the AM-FM and the CD-Tape . And by the way you can't replace the bulbs
behind the buttons on the steering wheel. They are in the switch assembly. Unless you
are good with a soldering iron. You may have to replace the switch.
- harofreak00
That's fine, I will replace only those small bulbs if you want.
I have no problem replacing those surface mount LED's in the steering wheel buttons, as long as they are provided to me. The switch assembly comes apart easy.
- harofreak00
bump
Anyone want me to do this at the MN meet?
Black Pearl
- Posts like an LG3
- Year and Trim: 2002 SSEi
Can you do anything with the HUD control? or the Cluster?
- harofreak00
Yes, but the cluster is a lot trickier
EWC88
- Posts like an L67
- Year and Trim: 01 Se
What would you charge for the cluster?
R.I.P 2001 Se :(
- harofreak00
I'm not sure if its something I would want to do for the masses. There is a very high risk of failure when taking the gauges off.
Black Pearl
- Posts like an LG3
Are those bulbs on the site as bright as our factory bulbs?
The bulbs that Andrew uses are nearly identical in output to stock bulbs.
- CMNTMXR57
So you're still doing this?
I have a few on my radio out. I've also wondered this, and have asked other GXP owners this, do the lights on the heated seat buttons light up? Mine don't. I haven't been able to get a clear answer on whether they do and my bulbs are out, or that just doesn't happen.
2007 Chrysler Town & Country Limited: Sold to neighbor
2003 Chevrolet Suburban 2500: Doeskin Tan - 8.1L Big Block... new plow truck
- harofreak00
Yes I still do this.
Yes heated seat switches are supposed to light up. Send those along and I can fix them also.
likeamojay
- Year and Trim: N/A
I only have 1 burned out bulb behind the LCD display. But do I have to order a replacement bulb off that corvetteradios website??? I don't want to pay $23 for 3 bulbs of which only 1 if possible. Could I get the bulbs for the display from Radio Shack?
Black Pearl
- Posts like an LG3
The brightest bulbs the shack has are dim in comparison to ours. Replace all three as preventitive maintenance so you dont have to have your radio opened up again
