Was talking brake upgrades with a Mustang guy
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
And he mentioned how he had thought he heard the Cadillac STS's of the 90's have the same struts as a 92-99 Bonneville.
If so what is so different we can't swap the 4 wheel disc brake setups off them? :???:
Really has me wondering. Also has me wanting to get to a salvage yard to do some inspecting.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
BillBoost37
Year and Trim: 00 Regal
Re: Was talking brake upgrades with a Mustang guy
Post by BillBoost37 »
My buddy the mechanic and former Caddy/Pontiac dealership mechanic told me this quite some time back.
The rears may or may not be worthwhile. Afterall they only do 25% or less of the braking.
97 Ei
97 GS
98 GS
olblueeyesbonne
01 SLE
02 GTP40th
02 SSEi
06 GP GT
If this could be done cheap enough it'd be a nice upgrade if not only for the 4-wheel disc look.
I suspect this could be an all day task requiring the replacement of the ABS module/pump.
Still something I'm going to look into.
Would be sweet to have 4 wheel disc brakes with slotted rotors at all 4 corners.
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
BonneMe
Post by BonneMe »
Putting bigger brakes up front would be much more beneficial, however you're still at the whim of the self-adjusters out back in the drums. I know many people have had to replace brakes over the years in this group due to the rears being out of adjustment, and then using the fronts much more then necessary.
wjcollier07
Year and Trim: ____
Post by wjcollier07 »
Rear brake parts of the same listing, possible donors:
Rotors
BUICK PARK AVENUE (1997 - 1999)
BUICK PARK AVENUE ULTRA (1997 - 1998)
BUICK RIVIERA (1992 - 1999)
CADILLAC ALLANTE 1993
CADILLAC CONCOURS (1994 - 1999)
CADILLAC DEVILLE (1994 - 1999)
CADILLAC DEVILLE DELEGANCE 1997
CADILLAC ELDORADO (1992 - 2000)
CADILLAC ELDORADO ETC 1998
CADILLAC ELDORADO SPORT 1993
CADILLAC ELDORADO TOURING (1993 - 1997)
CADILLAC SEVILLE (1992 - 1993)
CADILLAC SEVILLE SLS (1994 - 1997)
CADILLAC SEVILLE STS (1992 - 1997)
OLDSMOBILE AURORA (1995 - 1999)
OLDSMOBILE TORONADO 1992
OLDSMOBILE TORONADO TROFEO 1992
Calipers
CADILLAC CONCOURS (1994 - 1996)
CADILLAC DEVILLE (1994 - 1996)
CADILLAC ELDORADO (1993 - 1996)
CADILLAC ELDORADO TOURING (1993 - 1996)
CADILLAC SEVILLE 1993
CADILLAC SEVILLE SLS (1994 - 1996)
CADILLAC SEVILLE STS (1993 - 1996)
But instead of a heavy duty strut in the rear, like the 87-99 H bodies, they have a lighter duty, shock style strut in the rear.
In theory, it might be possible to use a Seville's hub assy, and strut, and then just connect it to a 92-99 bonne's lower ball joint and upper strut mount and have it work...however, it seems since they're not using a heavy duty strut like the H bodies use, that there is some sort of additional support needed to hold up against braking, impacts, etc. Using this theory would be interesting to test, but it doesn't seem anyone sells lower ball joints for these assemblies..so I'm guessing it is a permanent press fit deal.
Looking into all the parts on paper, it doesn't look possible without some major fabrication...or safe even if it did work.
Guess its square one...
John
