GEN V or ported GEN III w/SSIC?
- olblueeyesbonne
- Retired Moderator
- Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT - Location: Sauk Centre, MN
Which would be better?
I'm looking at what I will be doing this winter and am trying to nail down exactly what would be best.
Would a GEN V (polished inlet and outlet) with N*
or
Ported GEN III with SSIC and N* be better?
I have a ported GEN III that was supposed to have been ported already but the shop called to say he wasn't able to get to it and is going on vacation until September 29th.
I'm trying to decide before then if I want him to go ahead and port the GEN III (probably will considering I could sell for a good price and put that towards a GEN V, but would like the GEN V by late October for the last race of the season @ Rock Falls.
I also will be doing XS Headers this winter (if they can confirm they'll fit H-bodies) so this is something to consider.
or
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
bonnevillain
- Year and Trim: 2002 SLE
Re: GEN V or ported GEN III w/SSIC?
id say go for the ported Gen III and IC. the Gen V itself doesn't gain you much, it's just a little more efficient if you want to pulley down again.
- willwren
- Retired Admin
- Year and Trim: .
I agree. The GenV doesn't really gain you much. And possibly won't gain you anything without tuning. In fact, you'll probably be running it with a larger pulley. This means less hp lost in driving it, and less heat produced to achieve the same net result from a Gen3 with a smaller pulley.
The question is, what mods will you do to support the intercooler? Many intercool too soon in the game. Look how far Rogue went without an IC for instance.
- Allmachtige
- Retired Moderator
- Year and Trim: 2009 G8 GT
IMHO Cam should come before an IC.
I'd say GenIII in your case.
2009 G8 GT - White Hot
FMS Custom Cam, Yank 3600 SS, 1LE (ZL1) 3.91, SLP Longtubes, Magnaflow cat-back, Rotofab CAI, tuned via HPTuners
415/391
415/391
superchargedSSEi
- Posts like an LN3
- Year and Trim: 1996 SSEi
Gen3 since without a good tune you won't be able to use the GenV to its fullest. I'd also consider putting the money set aside for an IC towards other supporting mods instead since, IMO, an IC should be one of the last mods considered.
Aaron
1996 SSEi (year confused and on the road again at last) : swapped 4T65, cammed and intercooled among other things
Best ET: 13.208
Best trap: 104.96mph
Best ET: 13.208
gigolo
- Posts like an LN3
- Year and Trim: 1978 Trans am
1999 regal gs
2003 regal gs
y the time a person gets a gen v you would think that they would either have a tuner or would have someone that could tune for them. my advice get the gen v and watch the boards for a used IC core and build from there that is what I did I sat on my gen v for 8 months or more before I got it put on. now yes I have a tuner and yes I will ic but do it once and do it right and you will be happy.
Also wren explain what mods would be required that are so important that an IC would have no effect like you eluded too. look at the cobalts and the cobras and the thunderbirds they were all factory ICed and so pls explain how that is wrong. i would love to hear your wisdom
- willwren
- Retired Admin
- Year and Trim: .
Start here for some good information:
viewtopic.php?f=2&t=14
The point is that there are things that your money is better spent on in terms of actual FLOW improvements on the engine before it's worth going to an intercooler.
There's a suggested ORDER of mods, and intercooling is typically one of the last things on that list.
Dirthead Racing
- SSE Member
- Year and Trim: 97 ssei
12.67@103
I beg to differ slightly. I know what the SUGGESTED order of mods is, I don't agree with the V over IC. I SHOULD have put an intercooler on before putting a CAM in. I believe a person SHOULD put a IC in before spending money on a Gen-V, if planned properly the change down the road can be seamless. I SHOULD have put heads on before putting a CAM in. I think with a bonneville exhaust a TUNER and IC would not be the WORST second 2 purchases for a car behind an intake. A tuner in the RIGHT hands can net better results than CAI/TB/plug mods combined. An IC COMBINEDwith the tuner COULD be utilized to make up for the other INEFFICIENCIES. That's what I think about it.willwren wrote:Start here for some good information:
BTW can we add using RANDOM capital LETTERS to the LIST for bad Spelling puncuation, and proper GRAMMAR?
- willwren
- Retired Admin
- Year and Trim: .
Everyone has their own thoughts on it. Mine tend to be guided by INTENSE and the advice they've been giving for several years now.
It makes a wierd kinda sense to actually increase the flow capabilities of the motor before you increase the density of the intake charge by intercooling, doesn't it?
- Oldsman105
- Posts like a Northstar
willwren wrote:Everyone has their own thoughts on it. Mine tend to be guided by INTENSE and the advice they've been giving for several years now.
Not really .... Depends on the car.
Remeber that in the case of engine flow the L32 is little to no improvement over the L67 yet they threw the Gen V on it .
- willwren
- Retired Admin
- Year and Trim: .
Again, I form my opinions on the subject by deferring to INTENSE. After all, they've had the greatest success in modding L67's as far as our application is concerned, with the two quickest 1/4 miler's in their stable, as well as being a player in the FASTEST L67 on the planet.
This topic was started so Marty could get opinions. And that's what we're delivering. Some are getting panties in a wad, others are participating in the topic by submitting the opinions asked for.
- Oldsman105
Ok you form your opinions from Intense. I form my opinion from all the forums I have read including Clubgp which in a modding sense has plenty of expierence.
(done with that point) "Sorry for the hijack everyone"
Marty In my opinion I would say Gen V with N* tb. Having driven one of each example I prefer the Gen V combination. Also with the shortstack it tends to heatsoak and lose some of its effiency. Also marty if you don't pair a ported TB with the ported SC then you are shorting yourself of that combinations full potential. But then you need tuning which you then you might as well put a Gen V on. Also a more important point, the Gen V sounds better under WOT.
- 2000Silverbullet
- Retired Gearhead
My very biased opinion is to go for the GenV over the GenIII w/SSIC.
The GenV will lower temps about 25 F but even though the GenIII w/SSIC will drop temps 75 F, the actual temp difference between the two is really only 50 F.....and as pointed out, heat soak is an issue, so the gain could be negated.
You can drop another 50 F using alky injection or add the SSIC to the GenV.
2003 SSEi
- Posts like an L67
- Year and Trim: 2003 SSEi.
LOTS of Mods
2000Silverbullet wrote:My very biased opinion is to go for the GenV over the GenIII w/SSIC.
but you have to spin the Gen 3 faster to achieve the same performance as the Gen V so its really a wash
- agrazela
- Retired Gearhead
- Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired - Location: San Diego, CA
With the price of Gen5 dropping, it seems to me that these days one could choose either boost mod path:
Gen3 --> Gen3/IC --> Gen5/IC
Gen3 --> Gen5 --> Gen5/IC
Depending on what you find a deal on at the moment, which path you have the time and energy for, etc.
In either case, as was alluded to, a tuner would no doubt be needed to get the full potential. Also, as was suggested, one would expect that by this point, other supporting mods (intake, exhaust, cam, wideband etc.) would already be there.
(Off-topic perhaps, but IMO if you see yourself going beyond simple stuff like intake and rockers--whether s/c or n/a--a tuner and wideband ought to be among your first investments, so that you can "learn your car" before adding power to it)
Bone Stock
Retired
Bone Stock
Retired
- 2000Silverbullet
- Retired Gearhead
The rating of each is the same 90 CFM per revolution. The difference is the Gen V is more efficient producing a tighter seal and less heat thru lower restrictions.but you have to spin the Gen 3 faster to achieve the same performance as the Gen V so its really a wash
I am running the same 3.1 pulley with the Gen 5 as I did with the Gen 3 but I notice the lower temperatures.
We have enough issues dealing with leaking LIM gaskets.
Adding another cooling circuit could be a wash all right. Washing more coolant into the engine is another huge risk with an intercooler heat exchanger failure.
Not to mention the potential for vacuum/pressure leaks.
Dirthead Racing
- SSE Member
12.67@103
How much lower specifically? I've been wondering this for a while.2000Silverbullet wrote: I am running the same 3.1 pulley with the Gen 5 as I did with the Gen 3 but I notice the lower temperatures.
You honestly think a meth injection system with a solenoid that can stick pumping water/meth into your intake is any safer than an intercooler? I feel your post is very misleading. The bonneville community should know the number of 3800 IC cars significantly exceeds the number of cars with meth inj out there. Also, none of the quickest 3800 vehicles use meth/alky injection nor is it used on any of the major 3800 performance parts manufaturers vehicles. ZZP experimented with it and dropped the idea for an intercooler. The 3800 intercooler was designed and marketed as a viable solution to the inefficiency and issues that come with meth/alky injection. Perhaps another gearhead could clear this up for the bonneville community? My $.02.2000Silverbullet wrote: We have enough issues dealing with leaking LIM gaskets.
- danthurs
- Posts like an L36
- Year and Trim: 1997 Bonneville SSEi
Gen3 with the IC, cooling the charge is the best course to take.
Mods, CAI, Gatorback SC belt, 180 deg. thermostat, sparkplugs 2 colder gapped @ .050, 3.1" MPS, intense™ PCM, AeroForce scan gauge, Flowmaster series 80 muffler, 3" Magnaflow cat , INTENSE™ Street/Strip Performance Shift Pak, 1.9:1 roller rockers, Oil Restricted pushrods, CompCam #105 springs, CompCam heavy duty spring retainers and valve locks, 17" wheels, 245/45 FirehawkGT tires,slotted rotors, cermaic pads, Wideband O2, MSD Blaster coils, MSD 8.5mm sparkplug wires, Stainless steel TOG headers, HP tuner, P&P LIM and supercharger, SSIC
Getting ready to install cowled hood, Project on hold!
Objects in mirror are loosing!
- 2000Silverbullet
- Retired Gearhead
The minimum amount of heat added by compressing air to 8 psi at 100% efficiency according to Boyles Gas Law is 71*F.How much lower specifically? I've been wondering this for a while.
The compressor's efficiency will add additional heat. For instance if it is 75% efficient, it will add another 24*F of heat.
I have noticed about a 10*-20*F drop in temps after converting to the Gen5.
Engine heat soak will add additional heat. My engine heat soaks to 160*F.
The normal running temp of my SC outlet air is 120*F with IAT of 50*F, so the heat gain is 70*F
At 8 psi the SC outlet temp spikes almost immediately to 190*F, so that seems to correspond to the 70*F rise due to compression.
That means the other 70*F is due to compressor efficiency and heat transfer from the 160* engine.
The water injection will knock the temp down to 140*F at WOT so it cools about 50*F. Not as much cooling as the SSIC that claims 80*F.
I was referring to the risk of heat exchanger failure and dumping coolant into the engine in a very high quantity.
The meth injection is a very low volume system. It is very fail safe also. The solenoid failed closed so the engine just bogged from running rich. Still ran a 13.5 with no injection.
Last edited by 2000Silverbullet on Sat Feb 14, 2009 3:19 am, edited 1 time in total.
Dirthead Racing
- SSE Member
12.67@103
Good info2000Silverbullet wrote:The minimum amount of heat added by compressing air to 8 psi at 100% efficiency according to Boyles Gas Law is 71*F.How much lower specifically? I've been wondering this for a while.
