Bolt size?
skypilot
Year and Trim: 01 SSEi
96SE
Bolt size?
Post by skypilot »
Anyone know the bolt head size of the ignition coil pack bolts. I have tried 5mm-6mm, 7/64's and a bunch of other tiny sized wrenches with no joy. This is on the 2001 SSEi as when I did change one on my old 96 SE no problem.
ChildOfGod Motorsports..."burn rubber not your soul."
"May The GOOD LORD Bless You Where The Rubber Meets The Road"
Bonneville Pro COTM JUNE 2008
Ultra Boost
Year and Trim: 1994 Buick Park Avenue Ultra
Re: Bolt size?
Post by Ultra Boost »
Isn't it a 5.5mm? I thought that was the standard head size for most GM coil packs.
Needs more blower whine!
Re: Bolt size?
Yes, its 5.5mm, but 7/32nds is the closest you are going to get with a regular socket set.
The size is shared on all GM's..
skypilot
96SE
Re: Bolt size?
Post by skypilot »
thanks guys, went and got a 5.5 and changed all three units. Again thanks
