Driver's side A/C not cold
2000SE
Year and Trim: 2000 se
Post by 2000SE »
2000 SLE single zone system.
With the engine running, a/c on max & recirculate,
low side is 60psi.
High side 300 psi.
Should I add more charge?
If so, how high is safe for the low side?
J Wikoff
Re: Driver's side A/C not cold
Post by J Wikoff »
I think your pressures are in the high side of normal. I wouldn't go adding more.
What is your ambient temp? Your pressures are high. You have a problem. I'm guessing a clogged expansion valve (orifice tube).
