Bonneville hesitation.
CHRIS904
Year and Trim: 98 Bonneville SE
Post by CHRIS904 »
Hello got my 98 bonneville with 37k original miles. Car has sat for years anyways. Had to change a cam sensor and altenator. I got an issue we're when turning at a stop sign or red light the car has what feels like a mis fire. I get no cel or anything. The car runs great at Idle and high speed. Going to change fuel and air filter tonight. Any ideas?
DR.Camaro
Year and Trim: 1998 Pontiac Bonneville SSEi
Re: Bonneville hesitation.
Post by DR.Camaro »
You may need to check your ignition wire. coils and or spark plugs. Do you have any P0300s codes?
Dr. Camaro
Instagram: @Firebirds_and_Camaros_Hub
YouTube Channel: Firebirds and Camaro Hub
95naSTA
Post by 95naSTA »
Pull the codes even with no CEL to see if there's anything pending.
CHRIS904
Post by CHRIS904 »
I think it has something to do with fuel sloshing in the tank. It doesn't do it when the tanks fuel once you get to half a tank it will. I'm not too worried about it when the fuel pump fails I'll find out then.
