First - DTC P0420. It keeps showing up. Have run cataclean thru it and still illuminates. Is there a way to trick the ECM so it don’t come on anymore??
Second - Dual piston calipers. I’ve read somewhere that dual piston calipers would fit the Bonneville… true or false. If factual, what donor vehicle would I need to get them from and would I need the caliper mounting bracket?
Thank you for taking the time to read this post. All advice and help is greatly appreciated.
2005 SLE. Two questions
rynmcdonald
- Posts like an LG3
- Year and Trim: 2003 Bonneville SSEi.
- 95naSTA
- Year and Trim: 95 SLE
Re: 2005 SLE. Two questions
The electrical O2 spoof solutions were all shut down and taken to court for the most part. Mechanically you could try an O2 sensor spacer but I would just replace the sensor to start since it sounds like you have a cat.
There are many front brake options with varying degrees of effort to retrofit. Search this site for brake upgrades and also search w-body front brake upgrades since the front knuckles are the same wrt hub/brake mounting.
- harofreak00
I've tried o2 spacers without success. Just plan on getting a new cat. I recommend the Magnaflow 33906HM. Don't waste your time/money on any cheap Chinese cat as they will set the CEL as well.
Bonneville GXP brakes or W-body brakes are the upgrade you're hearing about. For the GXP upgrade, you need: the bigger rotors, the caliper brackets and the special collared bolts that hold it to the knuckle, the dual piston calipers and also the brake hoses. Pretty simple upgrade.
- nos4blood70
- Year and Trim: 2003 SLE
You can use HPTuners to remove the code as well.
rynmcdonald
- Posts like an LG3
Are the said items for the GXP brakes available online?harofreak00 wrote:I've tried o2 spacers without success. Just plan on getting a new cat. I recommend the Magnaflow 33906HM. Don't waste your time/money on any cheap Chinese cat as they will set the CEL as well.
- harofreak00
I have used options, although you can easily source it all brand new.
Pads, rotors, calipers, brackets and hoses will all be available from any parts store or Rockauto
Bracket bolt: 89047763 ($5 each at the dealer, need 4)
