Need specific help on LIM ( Lower Intake Manifold) Part#'s
Posted: Mon Jun 13, 2022 1:12 pm
by Corvette95
I have been working on a family members 97 3.8 (K) vin car. I am having an issue with what part # is the updated LIM metal gasket in stead of the rubber. I have BOTH the GM part #89017825 and a Dorman kit part#6150-717. Well the side gaskets look the same. I am not sure which parts are supposed to be the updated metal design. I also have (but haven't bought) a Fel-Pro part# but it has additional parts(highlighted in yellow below) that I am not sure what they are of if the are for early (mine is early) or late build 97. My block does not have the locator tabs on either kit. I would appreciate some specific advise. Thanks!
https://www.flickr.com/photos/185372905 ... dateposted
https://www.flickr.com/photos/185372905 ... hotostream
Have not bought this kit yet.
Re: Need specific help on LIM ( Lower Intake Manifold) Part#
Posted: Mon Jun 13, 2022 3:32 pm
by harofreak00
GM #89017825 is the superior kit
Felpro MS98014T is the next best thing to GM, but does include some unnecessary parts
Dorman 615-717 is all plastic, JUNK
Use the Dorman 47065HP metal elbows, but replace the junk Dorman o-rings with GM
smaller: 25537068 x3
larger: 24502846 x1
Posted: Thu Jun 23, 2022 5:41 am
by Corvette95
thanks for the replies...next question is about install.... I need the installation order especially when the serpentine belt goes on for the following items: New Dorman upper intake with metal stove pipe, lower intake (NOS GM), complete belt tensioner with metal coolant tubes, power steering pump, alternator..etc. I am most concerned with when the install the new belt. should be done. I remember it being behind the tensioner but it's been a while due to working on this after work since January. I also am installing new pass side motor mount. I would appreciate guidance on this. I bought a FSM but it doesn't help with all these items being pulled off. I would appreciate any pictures as well of a stock 3.8 engine as I am also replacing all the emissions vacuum lines, cruise cable etc. I will also take advice of there all should I put the "right stuff" black RTV. I plan on installing the LIM gaskets dry with RTV in corners. Should I RTV more or anywhere else? (this is a first gen car with the smaller side gaskets. no alignment dowel LIM). Thanks in advance.
Posted: Thu Jun 23, 2022 9:05 am
by harofreak00
Check out the TechInfo section at the top. Everything you're asking about is in there with detailed picture write-ups:
Change Upper Intake Manifold & Lower Intake Manifold gaskets
Change Accessory Belt (95-99 Series II engines)
