If removing the throttle body...Why drain coolant?
Posted: Sun Feb 13, 2022 3:00 am
The forum for Pontiac Bonneville enthusiasts
http://www.pontiacbonnevilleclub.com/forum/viewtopic.php?t=53165
nos4blood70 wrote:I wouldn't drain the coolant, but you will have some dribble out. Just put some rags under that area and then just make sure your reservoir has the correct amount of coolant. With how little you use, it'll self bleed. At least it has in all of my experiences with removing the TB or the upper intake.
