2nd AC Delco new starter... Need help....
wpbrink
Year and Trim: 1998 pontiac bonneville se
Post by wpbrink »
1999 Pontiac Bonneville. 2 OEM Brand New Ac Delco starters have been installed. Vehicle started and ran fine... Battery fully charged, I get a click when I attempt to start. I'm totally lost because it's something else obviously besides the starter....
95naSTA
Re: 2nd AC Delco new starter... Need help....
Post by 95naSTA »
If you jump the signal terminal to the +12v terminal on the starter, will it try to start?
If your security light flashing?
wpbrink
Post by wpbrink »
If I physically get under the starter and do the jumping, yes it will start.....
95naSTA
Post by 95naSTA »
So it's either your starter relay, ignition switch or security system not allowing the starter relay to work. If its the security system, the security light will be flashing on the dash when you try to start it. Usually the security thing is the contacts on the key chip being worn down and/or dirty.
