External engine oil cooler
Posted: Tue Nov 10, 2020 3:05 pm
by rynmcdonald
I haute wondered if there is an aftermarket part to colt on that would allow for this. Have done it with the transmission.
Re: External engine oil cooler
Posted: Wed Nov 11, 2020 3:29 am
by 95naSTA
Yep. There are a couple ways to adapt one from the oil filter adapter
The 92-99 Bonneville had an external oil cooler option with a sandwich plate and hard lines. The oil filter adapter is in a different spot than your car though. If you can find one of those, it might work on your 00+ H-body oil pan and oil adapter. It'll definitely thread on, I've just never seen someone try to mount and route lines with that pan/adapter.
The other option is an oil filter relocation kit. I have this setup with -10AN line, a Mocal remote oil thermostat and an Earl's cooler.
Posted: Mon Dec 20, 2021 11:40 am
by camopaint0707
why would you want/need this though? Do you plan on tracking the car?
Posted: Tue Dec 21, 2021 5:14 am
by 95naSTA
For me in particular, because I'm running over 10.5:1 static CR.
For others, hot climate, towing, etc.
