Experimental headlamps
Posted: Sat Jun 08, 2019 2:08 am
I saw an old post from 2010 about headlamp modification, as follows...
Second, putting a hi beam lamp in the low beam side...does this blind other drivers or cause any un-needed grief?
No, and no. You just have to trim off a plastic tab from the high-beam bulb connector, and narrow down the plastic tabs on the outer mounting ring. Dremel takes care of it in about a minute.
WARNING:
#1 State laws usually don't permit any such thing.
#2 Federal laws are more stringent than state laws and supersede them.
#3 It's dangerous
I cannot understand why someone would do this! It takes months, just to develop a lamp's optics by highly skilled optic engineers, designers to package it and then go to quality control, finally hitting production. Look, I've flown in a jet. It doesn't mean I'm going to fly it because someone tells me it's as easy as it looks. Would you want to put your 16 year old behind the wheel of this "experiment on wheels?"
WARNING:
#3 It's dangerous
