1999 Bonne Dashboard lights
- ProblematicBonneville
- SE Member
- Year and Trim: 99 Bonneville SE - Junked :(
at night the dashboard and radio lights are not working, lights like the airbag, seatbelt, break, and security lights light up, but other than that there is no other lights on the dash.. ive checked almost every fuse under the drivers foot well and they all seem fine. what should i do?
- J Wikoff
- Year and Trim: 1992 SSE
Re: 1999 Bonne Dashboard lights
Those all go through the dimming circuit in the headlight switch. They are known to die from time to time and get kinda melty looking when you remove them. Assuming you don't have it fully dimmed. You wouldn't be the first...
- SE Member
I took out the twilight sentinel switch and there where a few prongs that where burnt and crisp, so i guess ill have to buy a new one? but if i do is there anyway to prevent this with the new switch?
- J Wikoff
No, not really. Hopefully they've updated the design, but who knows.
- SE Member
Alright, thanks man!
