*Solved* Adjust column shift indicator
Posted: Tue Apr 16, 2019 10:42 am
by ProblematicBonneville
So i need some help aligning the column shift indicator, say if im in drive the needle will be closer to natural and when in reverse the needle will be behind the dash closer to park. i read a older post on here about how to fix it but im pretty sure i misunderstood it because it didnt work, if someone knows how to fix this please let me know and also pictures would be nice as well.
Re: column shift indicator
Posted: Tue Apr 16, 2019 3:13 pm
by MattStrike
There is a little metal cable that comes out the bottom of the cluster and clips to the bottom of the column. Adjust the location of the clip to adjust the indicator alignment.
Posted: Wed Apr 17, 2019 12:36 pm
Wow thanks, didn't know it was that simple!
