transmission not going in gear ??
javelin389t
Year and Trim: 2004 SE bonneville
Post by javelin389t »
looking for some help on a an 2004 bonneville SE that after driving an hour ago and then parked will not go in gear. shifter/indictor move through all gears and cable and shifter lever are moving but car will not move. any help is appreciated. anyone ? when car is in park i cant push so i assume park is ok. on jacks wheels spin freely in opposite directions which i believe is normal. but puting shifter through reverse and 123 and no go? engine sounds fine. fluid level is ok. i have a bad feeling. seems like something inside the tranny. tranny was removed and rebuilt approx. 4-5 years ago.
Re: transmission not going in gear ??
If you put the gear stick into 1 or 2 does the car still not move? It only happens once the car is warm?
javelin389t
no, will not move at all. just left the house on a flatbed to the garage. we'll see what they say.
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
I parked mine in a parking lot and backed out, put in gear and nothing. Popped into "1" and it moved but slipped. Ended up being a broke 1st gear band, did a rebuild at that point. If yours doesnt move at all in any forward or reverse gear then it could be a full rebuild or something like a the filter seal failed. have seen the filter seal pinch or even the filter fall off in the pan completely and suck up air then acts as a bad trans (no trans fluid pressure) but usually its not a simple fix. Hope its a easy fix.
Thank you,
Shane
Shane "RedZMonte"
2004 Z16 Z06: Virgin
javelin389t
garage said something in tran. came apart. they dropped pan and from what they can see everything was ok. i'll try selling if no interest, i guess its going to junkyard.
