What kind should I be looking at?
Godking Faith
Post by Godking Faith »
I've got an 00 Bonnie SSEI. Still stock radio so if I want audio from phone, I'm using tape cassettes and lighter adapters. I want to put a nice touchscreen in. Not sure however what I should be looking at. Be it type or cords etc.
Re: What kind should I be looking at?
You can go on Sonic Electronix and get everything you need there. Be aware that you'll need to cut out a lot of plastic behind the factory radio in order to make any aftermarket radio sit flush in the dash.
J Wikoff
Post by J Wikoff »
Another thing you could do is a Bluetooth FM modulator. No cords or tape adapters.
https://www.amazon.com/SmartCharge-Blue ... +bluetooth
Actually, it looks like they have a newer one.
https://www.amazon.com/Roav-SmartCharge ... _title_wld
