how do you know if you have a bose system or factory amp?
Posted: Wed May 30, 2018 12:07 pm
I want to install an aftermarket radio in my 01 SLE. I'm trying to find the right wiring harness, but can't figure out if I have a bose system, or even a factory amp. Nothing in my car says bose on it, so I'd imagine that it doesn't have a bose system, but I just want to make sure because I've heard of them being unmarked in some cars.
These are the two harnesses they offer on crutchfield:
https://www.crutchfield.com/p_541RP3GM1 ... ml?tp=3486
https://www.crutchfield.com/p_120LCGMRC ... ml?tp=3486
The first one is capable of retaining a factory amp, if you have one. That's what they give you when you select that you have 8 speakers in your car. The second one is what they give you when you select 4 speakers. Another problem is that mine has 6, two on the front doors, two on the rear deck, and two tweeters on both front doors. I'm just going to use the second one if it turns out that i don't have a factory amp.
This is what is in the trunk, are any of these an amplifier?
https://www.gmforum.com/attachments/aud ... -trunk.jpg
