Easier to pull engine AND transmission-only engine or trans?
Posted: Sat May 12, 2018 12:35 pm
by MKMike
I have to replace the rear crankcase cover gasket, as it has blown out and created a huge coolant leak.
Not looking to do extra work or to make things more complicated.
Which is the easier to do option; Pull engine & transmission; pull transmission or just pull the engine?
How does anyone get the nose of the car high enough to remove anything from the bottom?
I already have bars to support the engine, from a subframe change but am not averse to getting a hoist and engine stand.
Just looking to save myself grief.
Kind of shocked that at 90K my engine needs such a repair.
Re: Easier to pull engine AND transmission-only engine or tr
Posted: Sat May 12, 2018 1:50 pm
by michtom
Pull the engine using a cherry picker! Not that bad of a job!
Posted: Sat May 12, 2018 3:19 pm
by MKMike
Thanks, Michtom.
So, just the engine alone?
Any decent brands--or brands to avoid?
Posted: Sat May 12, 2018 5:10 pm
by michtom
Yes, engine alone! Much easier if you don’t have a hoist. Otherwise you would remove the transmission to access! No suggestions for gaskets other than quality, as you don’t want to do the job again.
Posted: Sat May 12, 2018 8:03 pm
by MKMike
Thanks again!
I should have been clear, I was wondering which brands make good quality cherry pickers.
Posted: Sat May 12, 2018 8:42 pm
by dougtoth
I have never heard of replacing the rear crankcase cover gasket.
Is that an unusual problem?
90K is nothing on these engines.
I just passed 150K on the 2001 and have 259K on the 2000.
Sorry to hear about this problem.
Posted: Sun May 13, 2018 7:07 pm
by MKMike
Been told it isn't uncommon.
Perhaps it tended to occur on some years and not others.
This one is a 2002 SSEI.
Anyone who has knowledge of which brands are/aren't good on the hydraulic engine cranes/cherry pickers or whatever name you prefer, I'd appreciate if you let me know.
Posted: Tue May 15, 2018 9:03 am
by harofreak00
I had a project car with that rear crankcase cover gasket leak, the coolant just poured out. With a lift, its easier to drop the trans out the bottom and fix it in the car, but if you only have a cherry picker, the engine out the top is the best way. I wouldn't worry about the brand, the 500lb engine is well within the specs for even the cheapest lifts.
Posted: Tue May 15, 2018 1:14 pm
by MKMike
I had hoped you'd reply, as you have the most experience in Bonneville repairs.
Thank you.
As for lifts, what brand do you recommend for home lifts?
I don't have a cherry picker or lift, yet.
Thanks again.
Posted: Tue May 15, 2018 2:48 pm
by harofreak00
Harbor Freight or Northern Tool for the cherry picker would be fine.
The lift I have in my shop is an Eagle Lift, about 20 years old. The lift was here when I bought the building. I have no idea what I'd recommend for a home use situation.
Posted: Tue May 15, 2018 4:15 pm
by MKMike
Thanks again!
