2002 SSEI
Kevin Amstutz1
Year and Trim: 05 red GXP, 05 white GXP, 03 SSEI, 02 SSEI
2002 SSEI
Post by Kevin Amstutz1 »
I have an issue with my auto climate control. Never had any issues til I went out the other morning and only had center duct mode. No other modes would work when selected. Took my Tech 2 and recalibrated all the HVAC actuator control motors and still nothing. The hot and cold actuators will function properly, but the defrost, floor and center duct mode will not. I have heat from drivers and pass sides. With my Tech 2, I can select the Defrost to AC actuator to move from the center duct mode to defrost mode and the motor actuator functions and I have defrost. But the manual mode select will not move to defrost actuator. I checked all the fuses and I have a B0252 DIC. The tech 2 voltage shows under 5v. Any thoughts?
Kevin
05 GXP Red, 05 GXP White, 03 SSEI, 02 SSEI, Sold 98 SSEI, 98 SE, 98 SLE, 98 SSE
96 SSEi
Re: 2002 SSEI
Post by 96 SSEi »
looks like its the blend actuator or the head unit: you can inspect the door blend to see if it can move to all positions while you change settings.
Kevin Amstutz1
Re: 2002 SSEI
96 SSEi wrote:looks like its the blend actuator or the head unit: you can inspect the door blend to see if it can move to all positions while you change settings.
I can use my scanner to move the actuator from floor to defrost or defrost to floor, so I don't see where I have a bad actuator. Head unit is what I was wondering.
96 SSEi
Re: 2002 SSEI
Post by 96 SSEi »
if reset wont help, test with working head unit.
Kevin Amstutz1
Re: 2002 SSEI
What happened is I had a bad mode actuator and a cracked gear in the drivers temp actuator.
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Re: 2002 SSEI
Post by MKMike »
Thanks for reporting back on the causes. It helps us all.
Surprising that it was 2 actuators.
Kevin Amstutz1
Re: 2002 SSEI
The drivers temp had a split gear at almost the end of travel and the mode selector had me going that I could control the actuator with my scam tool and not the head unit. What convinced me was comparing the counts between my other car wasn't the same.
