Page 1 of 2
96 vs 97 PCM?
Posted: Sun Jan 21, 2018 1:26 pm
by Detailpro116
Hello all, new member, first post.
I have a 96 SSEi and have recently purchased the ZZPerformance Stage 1 kit which includes a tuned PCM.
Apparently the tuning software only works on 97 and newer PCMs. I sent my 96 PCM to ZZP and they informed me that both of their tuners could not read my 96 PCM, and offered to tune a 97 PCM and see if it works in my car.
So, my question, before everything arrives, is will the 97 PCM work in my 96 car? What is the difference between a 96 and 97 that makes them compatible or incompatible? Is there any known way to tune a 96 PCM?
If it makes any difference at all my car is a Canadian Spec built 3/96.
Thank you in advance for any help! See you around the boards!
Mike
Re: 96 vs 97 PCM?
Posted: Sun Jan 21, 2018 4:56 pm
by RJolly87
The big hangup is that the '96 came with the 4T60e-HD, and the '97 got the 4T65e-HD transmission.
Re: 96 vs 97 PCM?
Posted: Sun Jan 21, 2018 6:30 pm
by Detailpro116
Oh ok. So basically the 97 pcm won't work due to the tranny change?
Re: 96 vs 97 PCM?
Posted: Mon Jan 22, 2018 1:04 pm
by 95naSTA
Either way I do believe you would need to do some repinning but 97 SEs still had the 60e. So it could be possible.
Try searching this forum. This has definitely come up before and maybe figured out.
Re: 96 vs 97 PCM?
Posted: Mon Jan 22, 2018 8:25 pm
by Detailpro116
I'll definetly have to do some more research then. I talked to ZZP and they were hoping that the 97 PCM will override the transmission line pressures and just go by the shift points. It will be arriving tomorrow so I will install the PCM tomorrow night, see what happens and report back, I don't mind having to repin a little bit, that's simple.
It really sounds like these are the odd ball cars of the group with lots of specific stuff to them.
Re: 96 vs 97 PCM?
Posted: Tue Jan 23, 2018 2:17 am
by bs009
You will definitely have to do some repinning to make the 97 pcm work in a 96 car. There are a LOT of pins that need to be moved to make it work, it's not even close. You could make it happen but it's most if not all pins that need to be moved. It might be easier to grab a whole 97 harness from a donor car. I would go over all of the wiring diagrams in a lot of detail if you just want to repin the harness.
ZZP should know that 97 pcms have no problem controlling the 4t60e. with the 4t60e, the line pressure is controlled by the vacuum modulator so there shouldn't be any issue with that part. I haven't had any luck with changing the WOT shift points in a 4t60e car. I've found that changing those tables at all with either year pcm causes the trans to not shift at all at WOT.
The 96 PCM can be tuned with DHP, but it is definitely an odd ball. It has a lot less functionality than the 97 PCM's.
Re: 96 vs 97 PCM?
Posted: Tue Jan 23, 2018 4:06 am
by 95naSTA
Also hit up
http://www.gmtuners.com/. I'm pretty sure they can tune 96s.
Re: 96 vs 97 PCM?
Posted: Wed Jan 24, 2018 8:56 am
by Detailpro116
So want some interesting news? Plugged the pcm in and the car fired right up and ran and drove properly and didn't do anything goofy or throw any codes...yet. I only drove it around the block before I verified the ran the can and then tore into it to install my pulley and all the other goodies.
And little did I know you have to remove that whole stupid engine mount bracket to do the belts....
Re: 96 vs 97 PCM?
Posted: Wed Jan 24, 2018 2:55 pm
by bs009
I looked through my notes again to double check since that didn't sound right at all. Looks like I had the 96/97 swap mixed with the 97/98 swap.
96/97's are very similar if not the same.
98-02's are completely different from the 97/96's.
I'd be interested in hearing if the TCC works properly though, I remember another person having an issue with it working on a 97 pcm in a 96 car.
Re: 96 vs 97 PCM?
Posted: Wed Jan 24, 2018 6:29 pm
by Detailpro116
I will report back with performance and issues once the car is back up and running in the next few days. I currently have to fight with replacing both belts before I can drive it again.
Re: 96 vs 97 PCM?
Posted: Thu Jan 25, 2018 12:39 am
by Detailpro116
Got everything installed and the car running tonight. Runs and drives great. Everything seems to work as it should and is noticeably much faster and fun.
Re: 96 vs 97 PCM?
Posted: Sun Jan 28, 2018 2:57 pm
by Detailpro116
So after a couple days of driving now I am throwing a P0717 turbine inlet speed code. After doing some reading, it seems like the PCM could be causing this.
Re: 96 vs 97 PCM?
Posted: Sun Jan 28, 2018 11:10 pm
by Detailpro116
Ok, so I went on a 2 hour highway drive and the car drove amazing even with the CEL on for P0717. Then on the way back the car would not shift into 4th or OD. Basically stuck driving in 3rd at 55mph at 3500-400rpm.
Re: 96 vs 97 PCM?
Posted: Mon Jan 29, 2018 2:07 am
by Detailpro116
Update. Drove 2 hours at 100km at 3800rpm in 3rd gear with the CEL on. Got home, put the stock PCM in and cleared the code and the car runs and shifts normally with. I CEL. So i guess the new pcm doesn't like to play nice with the trans line pressures and shift points.
Re: 96 vs 97 PCM?
Posted: Mon Jan 29, 2018 5:48 pm
by bs009
I would let ZZP know about the issues you're having. The 97 PCM should work fine with a 4t60e, there must be something in the tune that it doesn't like though.
Re: 96 vs 97 PCM?
Posted: Mon Jan 29, 2018 6:27 pm
by Detailpro116
Yes I have emailed them and waiting for a response. I drove the car to work and back today on the stock pcm with no issues.
Re: 96 vs 97 PCM?
Posted: Mon Feb 05, 2018 5:50 pm
by Detailpro116
I've tried to plug the ZZP PCM in a drive the car a few more times. Each time it either throws the same P0717 code as soon as you start the car or will come on after a minute or two. Or, the car may run fine with no CEL but will still not shift into 4th. It takes off and runs up to redline in all 3 gears like a bat out of hell and literally tops out at 140kmh/85mph in 3rd at redline.
ZZP has said to send it back and they will retune it to delete the code and hope that works.
I just find it strange how it worked so well for a few days and then suddenly on the same long trip it just went stupid. I would really like to have the tuned PCM work for this car, it makes a night and day difference in the shifting. I guess we will wait and see.
Re: 96 vs 97 PCM?
Posted: Wed Feb 14, 2018 11:19 am
by Jrs3800
The 97 PCM with the with a 97 SSEi tune will only properly control the 4T65E.. The 65E only uses a PWM solenoid for TCC lock.. Where the 96 4T60E uses a TCC on-off and PWM apply Solenoids So the 96 4T60E will never lock up with the 97 L67 Tune..
The codes you see are due to the PCM receiving no pulses from sensors that the PCM is looking for as the 4T60E does not use these sensors..
From what I have researched and learned, its superposed to be possible to run a 98 PCM with the L67 bin file but the 98 has the fuzzy logic to control either transmission, its a matter of turning certain items on or off and possibly zero out a few tables... I have always wanted to try this on my cars but just have not had the time to test it out..
There is a fiero forum out there that has some info on it, the guy knows how to do it but charges for it.. If I ever figure it out, I will post it in Tech Info for everyone.. And if you beat me to it, I'll love you forever...lol
Re: 96 vs 97 PCM?
Posted: Sun Feb 25, 2018 8:07 am
by Detailpro116
That's interesting to know now. I sort of figured those codes that were popping up had something to do with the lock up after doing some reading. I've sent my PCM back to ZZP to have the P1810 and P0717 codes tuned out of it and see what happens from there when I get it back in a week or so.
I can't recall at the moment, but didn't one of the 97 Bonneville models retain the 4T60E? I think this is why ZZP is hoping the tune will work with removing the codes. From the beginning they were skeptical if this PCM was going to work, so this is a learning experience for all of us.
I suppose if I really wanted to go through the effort, I could swap to a 4T65 tranny couldn't I? Time, difficulty and cost are not really an object on this car. It's a project and a play toy for me.
Re: 96 vs 97 PCM?
Posted: Sun Feb 25, 2018 1:19 pm
by 95naSTA
96 L36 had a 60-e and L67 had a 60-hd.
97 L36 had a 60-e and L67 had a 65-hd.
98+ were 65-e and 65-hd.
