Cylinder heads: Cleanup, Rebuilld, or Replace?
Posted: Tue Jan 16, 2018 10:05 am
by gk35
1994 Bonneville, 3800.
Severe overheating issues. After replacing radiator,thermostat, UIM and LIM gaskets with no help in overheating, decided to pull the head cylinders to check gaskets. Lo and behold, 90% of the water ports in the head gaskets were completely clogged.
So now I'm wondering if I should give the cylinder heads a good scrubbing and pop them back on, or have the cylinder heads rebuilt (i.e. valve job- something I don't want to do myself), or simply purchase rebuilt heads for around $250 each.
She's got 200K miles on her. And I plan on using her as my DD for at least another 50K miles. Any recommendations?
Re: Cylinder heads: Cleanup, Rebuilld, or Replace?
Posted: Tue Jan 16, 2018 10:30 am
by MattStrike
Overheating an engine can lead to cracked heads. The point where they tend to crack is the narrow spot between the valves. Use a fine wire wheel to clean the metal there until it's shiney and you can see if they are cracked. Might need a magnifying glass and flashlight to see any cracks.
If they are not cracked, you should be OK with a good cleaning and reinstall.
Posted: Tue Jan 16, 2018 11:28 pm
by 95naSTA
You can heat any suspect areas with a torch to see if oil bubbles out of the potential crack.
