Ive noticed this a few times....if sitting idling when warm n park, then put into gear, you feel it go into gear, step normal on the gas and it seems to start to move a little then a bang and it takes off...
Car has almost 200k,,,,just using as a winter rat....would a can of Lubegard Red help ??
2000 lesabre ,,tranny seems to slip a second when taking off
- nos4blood70
- Year and Trim: 2003 SLE
Re: 2000 lesabre ,,tranny seems to slip a second when taking
My car has the same issue. It comes and goes. It's called delayed engagement. You can read more about it here.
http://www.gmls4.com/index.php?topic=2773.0
rynmcdonald
- Posts like an LG3
- Year and Trim: 2003 Bonneville SSEi.
It's called "slide bang" caused by the heavy spring in the forward band cap that retains the spring. There IS a lighter replacement spring for it and it's about $10. Also recommend the superior shift kit along with the AFL valve replacement. Those will clear up A LOT of issues. I have built these transmissions.
