I recently purchased this car and before I did, it stalled on me a couple of times and had a long crank time one time after stall during test drive. With my past experiences on my NA 3800's I quickly thought that it might be a Crank Position Sensor or Fuel Regulator. They told me this had never happened and they would get it fixed. Long story short several different mechanics they took it to replaced numerous sensors and couldn't resolve the problem. They told me they were tired of throwing money at it and gave me a pretty decent discount to purchase as is. (Couldn't pass on the opportunity to own my first SSEI)
So I haven't done anything to it yet, but I've been able to isolate the problem. Seems that after the car has run and warmed up to normal operating temperature that when setting still (idling) and with the car in gear if I turn the steering and put additional load on the engine it stumbles and the rpm's drop like it's going to stall. I can do the same thing with it cold after start up and it keeps purring along. No sensor on the Power Steering pump on this year. Something (assuming a sensor) doesn't seem to be communicating with the PCM after it gets warmed up when the additional load of the power steering is applied while idling.
No Service Engine Light, Supposedly all the sensors have been replaced or checked and the TB was cleaned. I haven't not had to verify any of this as I've been trying to get the 2000 SE back to form after replacing the engine. Another issue with that.
Any thoughts or ideas on what to check would be appreciated or if someone else has had the same experience let me know.
