Where can I buy PREMOLDED brake lines?
Posted: Tue Nov 29, 2016 4:44 am
by wpbrink
1998 Pontiac Bonneville SE with traction control. Looking for websites that sell premolded brake lines with the best prices .
wendellbrink@cinergymetro.net
Re: Where can I buy PREMOLDED brake lines?
Posted: Tue Nov 29, 2016 8:48 am
by J Wikoff
If they are out there, I don't know where. I've replaced half my lines and had to bend my own.
Posted: Wed Nov 30, 2016 7:47 pm
by RJolly87
You may want to look second hand, but you will need to be looking where rust doesn't exist.
Like the desert southwest....
Posted: Wed Nov 30, 2016 10:23 pm
by redfury
Other than flaring the ends, which isn't that bad if you rent a decent tool, they make a new brake line that you can literally bend by hand, which means you can bend as you go or make adjustments on the fly...super easy to work with and pretty cheap for a roll.
Posted: Tue Dec 06, 2016 5:46 pm
by inition
I always make my own. I run into minor trouble with bubble flares. If I can't use the factory line where a bubble flare is needed, I buy one from Autozone, then double flare the other end and attach them that way. I have all kinds of spare brake lines laying around the garage. I only made a flare before placing the nuts once so far!
Posted: Wed Dec 07, 2016 2:41 am
by MKMike
Look on Ebay as there are at least a couple.
FineLines is one.
Of course you do pay for convenience.
Posted: Wed Dec 07, 2016 8:48 am
by J Wikoff
I've also found that premade lines can be impossible to install without removing other major components.
Posted: Sat Dec 24, 2016 6:43 pm
by SSEBonne4evr
Available through classic tube.
http://www.classictube.com/
Posted: Sat Dec 24, 2016 8:08 pm
by MKMike
If you want regular steel, not stainless try Ebay seller
http://stores.ebay.com/SSTubes-Prebent- ... 7675.l2563
I just bought a set for my 98 SE w/o traction control.
I didn't have to take anything apart besides the brake lines since these are made in sections for easier installation.
