Near future to do list.
jfields86
Year and Trim: 97 Pontiac Bonneville SSEi Supercharged
Post by jfields86 »
1.Finish getting the interior back together.
2.Replace front hub and bearing assemblies(passenger side is going out).
3.Replace front brakes(rotors,calipers and pads). Making an awful grinding.
4.Replace bushings in front subframe, drivers side rear.
5.New trans. pan, filter, fluid and gasket.
6.New oil pan and gasket.
Much more planned, but this is the stuff that needs to dealt with a.s.a.p!
Justin{Reed}
97' Bonneville SSEi [work in progress]
614justin
Year and Trim: 1995 bonneville se L36
Re: Near future to do list.
Post by 614justin »
I need new brakes and bushings and things too. I just got a 95 bonne se i had a break line rust against pass side frame near fuel filter and used a compression filter. I installed new front quick struts. I need some suspenion things tie rod end and various bushings i think.
jfields86
Post by jfields86 »
Brake lines are my least favorite! Replaced the whole set on the avy a few months back. Headache
Justin{Reed}
SSEBonne4evr
Year and Trim: 99 Bonneville
Post by SSEBonne4evr »
614justin wrote:I need new brakes and bushings and things too. I just got a 95 bonne se i had a break line rust against pass side frame near fuel filter and used a compression filter. I installed new front quick struts. I need some suspenion things tie rod end and various bushings i think.
You need to use double flares to join brake lines by law.
90 SSE Bonneville Sold but not forgotten.
