95 Bonneville SE Broken Brake Line
Bodydraggers
- LE Member
- Year and Trim: 1995 SE
I just got a 95 Bonneville from my father for my first car and it has a broken brake line and the parking brake is seize on. Where do I look for a new brake line? What do I need to install it?
___.Bodydraggers.___
96 SSEi
- Posts like a Northstar
Re: 95 Bonneville SE Broken Brake Line
hi, you can either replace the whole line- gm dealer and parts store have them or you can repair the existing leak by using a union and new brake line that you have to flare with a flaring tool....there are some videos of flaring brake lines on youtube if you are new to this
the repair will be about 50 bucks including the flare kit
where is the leak/ break on the car?
Bodydraggers
- LE Member
The whole brake line snapped and dropped out of my car so i currently have no brakes. The leak in the parking brake is right behind the rear driver side brake drum.
96 SSEi
ok, so you can buy the complete line or make it yourself with the fare kit
the parking brake is actuated by a cable- you can fix that after the line is repaired- so the leak is prob from the broken line
you got to get under there and inspect all the lines cause if they are rusted badly, the pressure of the fluid will make them pop a leak
there was a post on the site for lines for sale- try to search for it please............body-draggers? like zombies or what?
Bodydraggers
- LE Member
I understand now. Thank you. Also, Body Draggers as in dragging the body of mini-truck or any slammed vehicle shooting sparks xD
- Evan0801
- SSEi Member
- Year and Trim: White 1994 Pontiac Bonneville SE, 3800 Series 1.
No need to buy a flare kit unless you want to. Auto zone sells flared brake lines of different lengths already.
- TheJMFC
- Posts like an L36
- Year and Trim: '01 Saturn SL1,
'07 Grand Caravan SE - Location: Jenison, MI
I had to replace a few sections of line on my '93. A few things to note:
1) If you don't want to buy the flare tool or deal with pre-made lines, some parts stores loan out the kit.
2) Definitely inspect the rest of the lines. Two of my line failures were catastrophic, and one of them necessitated some unplanned "driving excitement" in order to avoid crashing. Scared a few people in the process. So if in doubt, replace anything that looks crumbly.
3) Not all brake fittings are flared the same way. Not all brake line is the same size. Be sure that your fittings, flare types, and line sizes are correct.
Aside from all that, it's really not that bad to do. Just be sure to bleed thoroughly afterward.
PS: Welcome.
PS: Welcome.
I'm Jon. I'm completely stock, no mods.
2001 Saturn SL1: "Nameless" Stock. Manual. 243,000 miles. Yes, original engine. No, doesn't smoke.
2007 Dodge Grand Caravan SE: "The Van" Stock. A miserable necessity of adult life. 165,000 miles.
Sold, probably dead: 1993 Bonneville SSE "The Work Beater" Stock. Tried to kill me a few times. Failed.
Sold: 1996 Buick LeSabre Limited, "The family car" Custom CAI, F41 Sways.
Sold/dead, but not forgotten: 1989 Bonneville LE "Bonnie, the Sport Utility Car" STB from '92-'99 Bonnie, Delco (Type II) Ignition system
- J Wikoff
- Year and Trim: 1992 SSE
Another note: The rear lines have pressure/proportioning valves in them. About the size of a lipstick tube, under the rear passenger door, one for each rear line. They rust up real good.
http://www.pontiacbonnevilleclub.com/fo ... ve#p144512
- Luxrain
- Posts like an LG3
- Year and Trim: Black 2003 Bonneville SLE
when the lines blew on my 03 i just wacked all my brake lines out to replace them, i used the unflared lines and used a rented flare tool (which i broke 3 flare tools). took me a long time to do it since i only had a few hours and i took out all the old lines but it wasnt the most terrible job ever but id strongly suggest it if one went
2003 pontiac bonneville Sle with kenwood sound system. Upgraded tweeters, door speakers, deck speakers, kenwood sub and amp. Rage r20 18inch rims. Front and rear KYB shocks and struts. GXP Strut tower brace.. She's a work in progress still
