Run the power wire (i had two) behind the overflow tank.
Sit the power wire flush with the fender and run it into the fender as well. The hood wont sit on it so dont worry about rubbing.
After running the power wire in the fender make a small incision on the rubber shroud. Feed the wire(s) through then.
Inside of the car under the passenger dash take off the plastic cover. If you feed the power wire through you wont miss where the wire comes out at. It may be hard to see but be patient.
Remember to run your rcas and power wires on different sides of the car. On each side you should take panels off. There is already factory wires running from the front to the trunk so just follow those wires.
I would include pictures of the wiring harness but i dont wanna take out the headunit and risk cracking the plastic cover. If i ever do ill take pictures and upload them here. This was the only way i could run the power wire without drilling a hole through the firewall. Goodluck!
