Key Stuck!!
Talk about the other 3800 powered GM cars, particularly for items not covered in other sections that may be unique to your year/model, and differ from a Bonneville.
Villainville
Key Stuck!!
Post by Villainville »
Hi, My daughter has a 1998 Pontiac Grand Prix and can't get the key out of the ignition. Any Ideas? Thanks , Bob.
2003 SLE silver/dark gray leather.
1996 SE white/gray velour --sold.
1992 SE Dark green/saddle leather --sold
1987 SE white/blue velour --sold (1st. Bonneville)
wjcollier07
Year and Trim: ____
Re: Key Stuck!!
Post by wjcollier07 »
Is the ignition turned all the way back to the full lock position? There could be a problem with the brake-shift-key interlock if it isn't going all the way back.
John
Archon
Re: Key Stuck!!
Post by Archon »
That seems to be a problem that is cropping up with some of the Grand Prixs. There are about 3 different possible problems. The most common is a small solenoid near the ignition switch. Others are the cable, and I believe there is a solenoid near the shifter. Sometimes, spraying some graphite oil in and near the ignition cylinder will free things up.
In the meantime, if you raise the steering wheel, and look under the column, near the ignition switch, there will be a small, round plastic cover that can be popped out. It's about the size of a dime. Push up inside there with something like the eraser end of a pencil, and that should allow the key to be removed.
Villainville
Re: Key Stuck!!
I would like to thank Archon and wjcollier07 for their help!!!! Bob.
Ragsdale
Year and Trim: 06
Re: Key Stuck!!
Post by Ragsdale »
Villainville wrote:I would like to thank Archon and wjcollier07 for their help!!!! Bob.
Does this mean you got it out?
