Hi all
So i noticed that my rear speakers stopped working today. I can still hear a little bass coming from the rear deck speakers but very light, nothing at all from rear door speakers. But if i set the fade all to the rear i get nothing. I do have a aftermarket radio in with GMOS-09. I checked all the connections and none came loose.
Anyone have this happen to them or know what to do?
Thanks, Keith
Rear speakers don't work.*Edit*
- irish91983
- Posts like an L36
1992 Bonneville SSEi (Sold) - Location: burlington, mass
2001 SSEi Bumbles
- nos4blood70
- Year and Trim: 2003 SLE
Re: Rear speakers don't work.*Edit*
So I'm assuming you have the stock Bose amp still in place? Maybe something happened there.
- irish91983
- Posts like an L36
I do. I noticed when I play a cd all works fine, but when i have my Bluetooth playing music thats when the rear door speakers dont work. Im guessing its a setting in the player or my phone.
2001 SSEi Bumbles
Hmm that is strange.. If it works with CD and Radio then it might be a separate adjustment for the BT feature that is fading the rears out. can you connect your phone to a USB? does it work that way? check the obvious "Fade" settings when in the BT mode.. some decks will offer different adjustments for each "Input" Type.
S
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
