2000 Transmission Replacement
2000Silverbullet
Post by 2000Silverbullet »
A question for those who have had experience removing and installing a replacement transmission.
What is the preferred method of removal? Remove engine first or drop subframe?
This will give me something to do this winter.....
Re: 2000 Transmission Replacement
2000Silverbullet
Thanks
Still trying to make up my mind if rebuilding this transmission is really worth it......
The more I look at the costs and other things that it will need like tires (half worn - performance 17" sizes are no longer available) and Stereo upgrade (+$1000), the more I want to sell it......
....and then also the availability of other parts if it gets into an accident......
Anyone want to buy it for $4500 ? I can bring it to Vancouver BC or the Island.
:evil:
Put a stock trans in and keep driving it?
Also, I still have that Bose head unit with the iPhone aux input wired into it somewhere in my garage. It just needs a face. I don't mind sending it to you if you reimburse me for the shipping cost. The wire it uses is for an iPhone 4. I got a little adapter for it when I got an iPhone 5. The little headphone jack on the adapter allows you to play music using any device, albeit without charging the device.
Hans
Year and Trim: '07 MDX | '13 TL | '06 GTO
Post by Hans »
2000Silverbullet wrote:Thanks
:evil:
I'd love to have it, I know how well you took care of it. I cant have another car in the driveway though. What is replacing it?
flatlander745
Post by flatlander745 »
Gantry with chain pulley to support engine/ trans. Dropped subframe by itself then lowered trans with floorjack.
2000 SSEi Galaxy Silver with New TEP Trans, A 62,000 mile engine out of grandma's car, all new front and rear suspension KYB/ Energy Suspension.
[url][URL=http://s871.photobucket.com/user/flatlander745/media/image-5.jpg.html][IMG]http://i871.photobucket.com/albums/ab278/flatlander745/image-5.jpg[/IMG][/URL][/url]
2000Silverbullet
Thank goodness Shadd gave me my Transepter pressure modulator back.
I bumped up the pressure in the transmission and seems to be working.
When Will from Overkill tuned it in the spring that's when the problem started.
I remember him telling me he turned the pressure down a little
2000Silverbullet
I think that the $100 electrical device just saved me thousands! :banana: :banana: :banana:
:bwoohoo:
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
and for future reference.. this is the easiest..
* Support engine
* remove sub frame
* pull trans out bottom
Shane "RedZMonte"
2004 Z16 Z06: Virgin
