Falling oil pressure
ThatOneGuy
Year and Trim: 1998 Bonneville SE.
Post by ThatOneGuy »
When my car gets warm and driven around the oil pressure slowly falls and makes its way to 0 and it starts dinging, telling me to check gauges but when I accelerate the pressure goes above 0 to halfway in the red. The oil is full and I already replaced the sensor so any idea what's causing this?
98 Bonneville SE(White)-Dead
03 Grand Prix GTP LE(White)-150k
96 SSEi
Re: Falling oil pressure
Post by 96 SSEi »
hi, what weight oil are you using?- 10w 40,10w 30....
my 96 used to drop but never to 0 - when I ran with 10w 40 it seemed to steady a bit.
ThatOneGuy
Currently 10 30. I was running 530 but then this pressure problem arises and I switched to 1030 with no luck in solving the issue so I replaced the sensor but it only helped for a week or so.
96 SSEi
Post by 96 SSEi »
may be the new sender is bad- how are the wires? does anything look damaged at the connection?
ThatOneGuy
Wires and connection all look good, I pulled it the other day and it wasn't torn like the old one but acts the same. It doesn't effect the car it seems but I'm curious because it's annoying but not to worried.
96 SSEi
Post by 96 SSEi »
you may try removing sender and cleaning the part that goes into block- do this at next oil change- it may be blocked by debris
AJT2004
Post by AJT2004 »
What brand of oil filter are you using? With your high mileage this could be a sign of a worn engine if regular oil changes where not done. To eliminate the easy stuff I would recommend an AC filter and switch to a 10-40 and see what happens.The next step would be to confirm oil pressure as this maybe only be a problem with the gauge cluster
Jfridge92
Post by Jfridge92 »
+1 on verifying pressure with a mechanical gauge. Is your motor showing any symptoms of low oil pressure, such as loud lifters, knock etc? If there aren't any audible symptoms and pressure checks out, there's probably something electrical going on. Usually when the cluster stepper motors go out, I don't believe they would cause the warning chimes to go off, so you're probably looking somewhere on the electrical path of the sender.
Joseph
1999 Infiniti G20T - Sold
ThatOneGuy
No there aren't any audible signs of low pressure, I will definetly clean it out next change and use 10 40, hope that helps! Thanks for all the suggestions!
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
Fram oil filters can be known to cause pressure issues, also some have reported that the AC delco senders are the most reliable ones. Some of the aftermarket ones do not last very long.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
JohnR
Year and Trim: 1997 Bonneville SE 40th Anniverary
Post by JohnR »
If mechanical gauge confirms low pressure I'd ask how are the lower intake gaskets? Send a sample of oil out to be analyzed by a lab. Small amounts of coolant might not be visible in the oil but may be enough to wear out the bearings. I also seem to remember it to be not uncommon for a 3.8 to need a new oil pump.
l67se
Year and Trim: 97 SE w/L67
Post by l67se »
My guess is you're gonna need a new set of rod bearings soon.
Seen this way too many times
ThatOneGuy
Also when the pressure hits 0 my battery gauge falls to about 10 but climbs back up when oil pressure rises. All lower gaskets were replaced about a year ago
