Power to pioneer radio, but no audio
lilanqel94
- Year and Trim: 97 sse
hello i recently bought a 97 bonneville. it came with aftermarket radio and has the stock bose surround sound, but you hear nothing. also, you can hear the power antennae trying to go up and down, but never see it! if anyone can help me out, it will be greatly appreciated.
oh and this isnt my first bonnie, i had a 99 se with a 12 in kicker hooked to a bonestock radio. lol the light for the radio didnt even work but man did that car pound!!
- nos4blood70
- Year and Trim: 2003 SLE
Re: Power to pioneer radio, but no audio
Remove the radio and check over the connections.
- terrancew3
- Posts like an LN3
- Year and Trim: 2009 G8 GXP
Does the radio at least power up? Cause if it turns on, but no audio is coming out, that means you don't have any power going to your bose amp in the car. My friend just had this happen to him on his '99 Grand Prix GT, and all he had to do was take the Blue or Blue/White wire from the deck and put that to the Red or Pink power wire from the wire harness. Then it worked fine.
2000 SSEi *sold 9/27/15* December '12 & May '15 COTM
2005 Grand Prix
2009 G8 GXP #418 of 1,829 November '15 TOCOTM
2005 Grand Prix
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
There should be a separate connector with one orange wire on the back of the stock radio, IIRC. That wire needs to be connected to the switched power source. I think it's orange at least, it has been about six years since I did it.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
lilanqel94
thanks for all your replies. @terrancew3, the radio does power up but no audio. i will do what you and nos4blood70 suggested, and get back to you with the results. again, thanks everyone
lilanqel94
ok little update. i took out the radio and saw the blue and white wire with black tape on it, so i took it off and connected it to an orange wire that was loose, and now have audio. its only working on the right side speakers but i'll just go back in tomorrow to see if everything is connected properly. and haro, you're right the wire is orange.
thank you guys for the help!
- terrancew3
- Posts like an LN3
The settings on the radio might only be set for right side only, you could check that. I doubt it, but its worth a shot. Otherwise you have some wires not connected that power the left side speakers.
2005 Grand Prix
2005 Grand Prix
lilanqel94
should have mentioned it earlier but yea i tried the settings on the radio with no success.
check all the wires on the harness, try connecting the Left speakers to the Right channel on the deck.. make sure its not the output on the deck that failed. if they are all correct then you might have the left channel out on the stock amp..
S
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
lilanqel94
i checked all the connections and were all correct. i couldn't figure out what was wrong so i tried balancing the audio to the left speakers. they're working but not like the right ones. all i did was balance them out so the audio comes out evenly through all speakers. and man, the stock rear speakers make the trunk vibrate, makes it sound like my old kicker i had in another bonnie
- nos4blood70
Make sure the speaker outputs on the harness are wired in phase.
