What can I do to get the most out of my fog lights?
natedawg061987
Post by natedawg061987 »
I apologize if this has been discussed before, but I've searched around and haven't found much on the topic.
The subject pretty much sums it up. I've got one good fog light bulb and one that's burned out.
What can I do to safely get more light output from these puppies? If there's anything I can do to boost their light output I'd like to find that out. I want to replace the bulb that's burned out, but if I'm looking at getting different bulbs entirely then I don't want to waste $10 on a basic Sylvania bulb just to replace it with something better.
Thanks in advance guys!
Nate
Dark Blue Metallic paint
80k miles
dadofone2011
Year and Trim: 2002 Galaxy Silver SSEi
Re: What can I do to get the most out of my fog lights?
Post by dadofone2011 »
There are some members that don't like them but you can always go HID for the bulbs. Then there are some projectors on ebay. Should be able to get what you looking for for less then $100.
Tyler
2002 Galaxy Silver SSEi "Silver Shadow" 181, xxx miles- DD, tinted taillights, 10000k HID low beams, GXP strut brace, carbon fiber overlays, GXP door bezels and vents and Aeroforce Interceptor Gauge, cleared corners, drilled and slotted rotors, painted calipers, Intense Stage 1 Performance package, smoked door reflectors.
2001 Galaxy Silver SE 119, xxx miles- RIP
2007 White G6 Economy 96, xxx miles- Wife's car, carbon fiber inserts, tinted windows.
BBamm
Year and Trim: 2004 GXP
Post by BBamm »
dadofone2011 wrote:There are some members that don't like them but you can always go HID for the bulbs. Then there are some projectors on ebay. Should be able to get what you looking for for less then $100.
I wouldn't advise using HID without a projector housing. I run a 3000k HID and I LOVE them but I have projectors. The light disbursement from an HID without a projector lens is terrible and even worse for oncoming drivers.
If you install a projector fog light and and HID or LED you will have an intense amount of light output tuned to the area needed and not blind oncoming traffic.
2004 Bonneville GXP Crimson Tintcoat- Casual fuel gauge | Brake Performance drilled/slotted rotors front and rear| Retrofit Morimoto mini H1 | clear corners | disabled DRL | 3000K HID fogs | 5% tint | K&N | Yakima rack with fairing, bike rails and kayak rack | Intermittent radio display
1995 Bonneville SSE Deep Amethyst Pearl- SSEI tails | 5% tint | 3 12jlw3v2 in custom enclosure -Gone
1991 Bonneville LE Blue- Alloy spokes -Deceased(deer)
Any bulb that has a higher output than stock is going to melt the lens. If you want more output, you'll have to replace the entire lamp assembly.
HIDs will blind people, and actually make it harder for you to see in bad conditions. And yeah, they'll melt the housing.
The fogs are more of an auxiliary/decorative light on these cars, as they are on almost all modern cars. Just put a clear halogen bulb in there if you want the most output in a safe way, both to the housings and yourself and others.
To increase your ability to see at night, you'll need to focus on upgrading your low beams with either some clear 9006 halogens, some HIRs, or a projector retrofit.
Archon
Post by Archon »
I've used these: http://www.autoanything.com/lights/69A1 ... aQodMmYAcw
They're a bit smaller than stock, and takes some fab work to install them. Being 55 watt, they light up the road better. Be sure to align them properly.
I seldom run my fogs, as I've found that using the 9012 HIR bulb provides enough light without them. You can read about them toward the bottom of the original post in this thread:
http://www.pontiacbonnevilleclub.com/fo ... 0headlamps
How to trim them, here:
http://shnu.us/HIR%20Trimming%20A.htm
If you're comfortable with some wire splicing….
http://www.theretrofitsource.com/closeo ... -fogs.html
Whitearrow3800 just did these on his car, hopefully he will post pictures of them soon. I'm considering it heavily now. Their output is quite nice.
1oldman
Post by 1oldman »
I replaced the clear halogen Fog Light lamps with yellow ones. They seem to work quite well, but I'm guessing not as good as the Morimoto. - BC
natedawg061987
Thanks for all of the input everyone!
I'd really like to put some HIR bulbs in my lows, but I want to know the most reliable place to get the true HIRs as opposed to the "new" HIR design, which I've heard doesn't have the same output as the originals.
Nate
80k miles
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Post by 2003 SSEi »
the fog lights are not designed to give additional driving output. They are designed to be a low short and wide beam pattern.
