I have a 99 Se with 232k on it. I've recently noticed that once car is at operating temperatures the oil pressure gauge goes from 40psi to a little lower and the longer I drive the car it seems lower at high way speeds it's at 30-35psi and then coming to a stop it sits right above the red.
Could this be oil sending unit? Or just a tired 3800? Engine doesn't tick or smoke still runs smoove voltage gauge also dips when braking then bounces back and bounces with the blinker not sure if issue is related though.
OIL PRESSURE ISSUE???
bigmandev92
- SE Member
- Year and Trim: 1999 Bonneville SE
216,000 Miles !
#GottaLoveGM
- RJolly87
Re: OIL PRESSURE ISSUE???
The best way to check is to throw a mechanical gauge on it and compare the readings. It's possible the sender may be on the fritz, but I would be more inclined to believe it given the behavior.
Also keep in mind that many things can affect engine oil pressures, a big factor being oil age and contamination. How long since the last oil change? How long has this been going on like this?
bigmandev92
- SE Member
216,000 Miles !
#GottaLoveGM
Changed the oil at 231k and its at 232220k now I wanna say I noticed this about a month ago dont recall it ever being like this before I would've noticed.
- Boreas
- Posts like an L36
- Year and Trim: 1993 SE
1997 SSEi 40th - Location: Chi-Town
The oil gauge clusters are notoriously inaccurate, hence the need for mechanical confirmation.
I forget the spec, but the rule of thumb is either 5 or 10 PSI per 1,000 engine RPM.
I had a Series 1 3800 with 242,000 where the oil pressure gauge had exactly the same behavior as yours, and the car ran like a champ, only junked it due to rust. Dont worry about it.
1993 Bonneville SE "Old Ironsides" 244,xxx - Junked.
1996 Bonneville SSEi "Double Trouble" 164,xxx - Stock
1997 Bonneville SSEi 40th "Purple Spaceship" 204,xxx - Aeroforce Interceptor, B&M 70264 Trans Cooler, Intense FWI, High-Flow Feline, non-Bose head unit w/ 5 band, Alpine 6x9's, 3.5 MPS, SD Headers, rear disc brake conversion. Future: 1.9 Rockers
1997 Buick Park Avenue "Blue Floaty Thing" 124,000 - Daily Driver/Winter Beater
bigmandev92
- SE Member
216,000 Miles !
#GottaLoveGM
Well that's good to know! Im gonna put the oil pressure gauge on it also just to check for sure, but it runs great still like you're saying your car did!
- nos4blood70
- Year and Trim: 2003 SLE
^^^^ That's what you want.Boreas wrote:10 PSI per 1,000 engine RPM.
You can check it mechanically if you'd like, but like Boreas said, it's likely nothing to worry about.
