3800 powered Sonoma. Let's chat
Talk about the other 3800 powered GM cars, particularly for items not covered in other sections that may be unique to your year/model, and differ from a Bonneville.
Wes
Post by Wes »
The budget is 1500 bucks.
The Philosophy of use is a daily driver that can handle hills, and or icy hills, and get up to highway speeds better than the weak ace 2.2L. It would sometimes pull a small boat, or trailer. It will predominantly be driven on 55 mph roads. I would like to achieve a mpg average of around 30. That is what the tutu currently gets as a bar. More would be a bonus. This is a rusty truck that has more into it than I could sell it for. The plan is to drive it for another 100k min. I don't want to turbo, or s/c, and probably couldn't w/o going over budget considering the extra tuning, and welding that would be required. That may also effect my longevity target. And being a daily, using 87 octane would be nicer on the wallet. I would por 15 the frame, and rust holes for now, and later weld in what needs to be replaced.
The plan is to find a decent L36 donor car for the engine. A wrecked F body would be ideal. The engine would not be rebuilt any further than replacing the intake gaskets, and plenum. Maybe some aluminum valve covers. This will take a few runs to the pick, and pull JY I am sure. Parts Galore be the one, for those familiar. I know many of the Michigan guys are.
My current debate to myself is the transmission. That's the topic I would like to ask for some suggestions currently. The truck already has a 5 speed. The F body manuals were also a 5 speed. If I were to dismantle a 3800 F body, this would be mostly plug and play as far as the PCM goes. But, would my current 5 speed clutch parts be compatible with the F body trans? And the 6 speed T56 is soooo tempting. The LS motors cruise 6th gear at like 2k rpm @ 70mph, and 30 mpg. I really wonder what a 3800 could do with that kind of gearing. I know I would need a bell housing adapter to mate the BoP block to the Chevy trans. Not sure what/if a T56 would need when it comes to pcm signals, or information sensors.
yourgrandma wrote:High
bs009
Year and Trim: 82 GP
Re: 3800 powered Sonoma. Let's chat
Post by bs009 »
Sounds like a solid plan!
AFAIK the 3800 should bolt right up to the transmission in your truck right now. Not sure about the clutch though, but I'd bet you'll have to use the F-body 3800 clutch. Also the F-body's used hydraulic clutches too so you might run into issues there if the truck uses a fork.
I'm currently in the middle of swapping an L36 and T5 from a 98 Camaro into my 82 Grand Prix, though the process has been haulted due to a lack of funding and time. I am debating my options and considering putting a t-56 in it or even just going all out and putting in an LS motor. I did find some research about the T-56 swap though: here and here. The adapters I found here won't even be in stock until May from what I was told. I also believe you'll have a hard time finding a T-56 at a decent enough price.
RJolly87
Post by RJolly87 »
At a $1500 budget, it sounds like job one is finding a cheap donor, and not being too picky about it.
Do you have your heart set on a 3800, or would you consider other options that present themselves, like a wrecked 4.3 or similar?
Wes
Post by Wes »
bs009 wrote:Sounds like a solid plan!
I didn't realize the 2.2 shared the same bell housing pattern, but according to wiki, you are correct.
http://en.wikipedia.org/wiki/List_of_GM ... g_patterns
Hmm, that makes things a little easier, and less costly if I were to go that route. I thought the F body T5s had a differnt bellhousing to accI wonder how well the current trans will hold to a L36 if it was intended for such a smaller engine. Were the F body T5s any different? Or is a T5 the same regardless of platform?
I have messed with a few 4T60s, but I am not very familiar with manuals, so I am not sure about the forks. Something to think about.
bs009 wrote:I'm currently in the middle of swapping an L36 and T5 from a 98 Camaro into my 82 Grand Prix, though the process has been haulted due to a lack of funding and time. I am debating my options and considering putting a t-56 in it or even just going all out and putting in an LS motor. I did find some research about the T-56 swap though: here and here. The adapters I found here won't even be in stock until May from what I was told. I also believe you'll have a hard time finding a T-56 at a decent enough price.
I have browsed of a few of threads on the s10 forums over the years. I will have to check out the ones you have shared too. Thanks for sharing.
I haven't searched for one. I ball parked 500 bucks in my head for one, or $75 if I get lucky enough in my parts galore diving.
RJolly87 wrote:At a $1500 budget, it sounds like job one is finding a cheap donor, and not being too picky about it.
If I am able to find a wrecked F body on CL, that would be great. If not, most parts would likely be sourced from a pick&pull JY. Last time I was there (which has been a while) the V6 motors were $150. L36 motors are plentiful there, so I should have an assortment of ones to choose from.
I have my heart pretty well set on a 3.8. I would say that I am still open to other swap suggestions though, but I am unaware of anything that would be as efficient, and reliable as an L36. 4.3s are good engines, but I feel they are less efficient, and slightly less reliable than a 3.8. 350 would be pretty much the same swap as a 4.3, but even less efficiency.
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
I remember seeing a Jeep Comanche with an L36 back in the day on cardomain, it was pretty nice. I know there is a 3800 firebird at Martins in Brownstown, couldn't tell ya if it was auto or manual though.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
Beware that the T5 is known to be a weak Trans.
Wes
Post by Wes »
nos4blood70 wrote:Beware that the T5 is known to be a weak Trans.
I have heard this before, but it was generally in threads where the build included boost, or 8 cylinders. Do you have any incite on how well they hold up to a stock L36?
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Post by MattStrike »
Isn't the T5 stock for the F-body 3800? I don't see why it wouldn't work out long-term.
Wes
Post by Wes »
MattStrike wrote:Isn't the T5 stock for the F-body 3800? I don't see why it wouldn't work out long-term.
That's what I am thinking for the most part, but I am just not sure of their longevity when a 3.8 is in front of it. Just because it was stock, doesn't mean it will necessarily go over 100K. FWIW, this current T5 behind the tutu is original with 200k on it. Still running strong with no grinding, or slipping. But typing that 200k makes me think I should strongly consider a rebuild if I stick with the current trans.
bs009
Post by bs009 »
There's a lot of variation in the T5 over the years. They came in a lot of different cars but it seems like the mustang's usually had the best versions of the T5. The best T5's to get from the factory were the "World Class" t5's which were "rated" for 300ft-lbs of torque. That's what's used in the 3800 F-body's. It'll probably depend on what year the S-10 is to determine whether it had a world class T5 or not. You'll also need the year to figure out how many splines are your truck's input shaft too.
Also, the S10 shifter is in a different location than the F-body shifter so you'll have to swap tailhousings if you switch to the f-body transmission.
Everything I've read about them seems to point to issues with shifting past 6200 rpm and 2nd and 3rd missing shifts once you put a lot of power into them. Also the case doesn't stand up to a lot of abuse. There's plenty of guys running stock T5's in their modded V8 mustangs without too many issues, but then again there are guys who have broken quite a few T5's.
You shouldn't have any real problems with it behind an L36 besides normal maintenance.
The T56 would be a bad trans, and blow your budget to smithereens. A good used one is $2k by itself. It's way too close-ratio and 6th is way too low, not to mention that it has a huge case which would likely require floor pan surgery. You'd also probably need to drop your axle ratio quite a bit to get it so it's not an absolute dog.
Stick with the T5. I've seen guys using them in older full-size trucks with little problem, behind V8's.
Wes
Post by Wes »
This truck is a 2000, so I guess it is the 300 ft/lb version. Although This says the world class versions were 88-92. I don't think they would revise them to be less than that 300 ft/lb. A stock L36 is 70ft/lbs less than rated. I see little need for 6k shifts for the way I drive this truck. Well, maybe on occasion, but not frequently :twisted: .
Saving this video for later. May be useful. This one too of course.
00Beast wrote:The T56 would be a bad trans, and blow your budget to smithereens. A good used one is $2k by itself. It's way too close-ratio and 6th is way too low, not to mention that it has a huge case which would likely require floor pan surgery. You'd also probably need to drop your axle ratio quite a bit to get it so it's not an absolute dog.
I have been searching around, and as you mentioned, the cost alone is an issue. I didn't realize they were so expensive. Considering the cost of a T56, your guys' input, and reading up more on the T5, I think I am sold on keeping the existing trans, or at least a T5 of some varying gear ratio.
Now I must keep my sights out for a donor car.
Good info on T5s here.
Wes
Post by Wes »
While trying to identify gear ratios, I found that the 96+ manual s10s got the NV1500. Not a T5. The F bodies had the T5 through 2002, so I thought the S series did too. I was wrong.
I am having a difficult time finding a power rating for these, but one article said they made them for 4 cylinder engines, and that the manufacturer made a NV3500 for the applications with more torque. So it would probably not be a good idea to use the existing trans for a L36.
Roadrunner
Post by Roadrunner »
Here's some info on T5's for you - T5 FAQ - Everything we know about the T5
Although not a torque monster, I wouldn't have any worries at all using it behind an unmodified 3800.
From the gear ratio table in the 9th post you see that some came with a .63 OD and also the ratio of 1st to top gear on the T5P.76 is almost identical that of a T56.
If you don't want to use hydraulic, the '83 F body T5's came with a mechanical clutch.
A 4th gen F-body PCM would get you going but you may need a custom tune if you want best performance / mileage.
dmitchel50
Year and Trim: 1996 Olds 88;
Post by dmitchel50 »
Wrecked 1996 Olds 88; 3800 motor
I don't understand too much of what you guys are talking about (I'm a novice mechanic), but if you're looking for a 3800 engine, I have one that isn't going to be doing me much good. I have a wrecked '96 Olds 88. Engine is good, right around 140-145 k miles. The right rear side took the hit. Rear door is crashed, but still opens, rear quarter panel is wrecked, but the trunk lid still works. The rear wheel is tilted in and I believe the strut mount is shoved in.
If you're interested in the motor (it would probably come with the rest of the car attached) let me know. I'm not sure I want to let it go to the insurance company for salvage.
Wes
Post by Wes »
pm sent.
Wes
Post by Wes »
As of now, I have the F body UIM, fuel rail, accessory/belt mounts, alt, P/S pump+lines, engine mounts/brackets, wiring harness, PCM, ICM, Coils, T-Stat housing, Oil Pan+p/u, and valve covers.
I have left on my list:
radiator
E.M.s (maybe Headers)
L36
T5
Any suggestions for items I should add to the shopping list?
If I went with the black pacesetters, I would be left with a $1000 budget, or about 800 if I went with the chrome version.
Wes
Post by Wes »
Ben, if you do change your mind, and decide to go with an LS motor, keep me mind for the L36, and T5 you have in your parts car. Or maybe even the car if you would want to save time on disassembling.
ratmonster
Year and Trim: 1989 Bonneville LE
1993 Roadmaster Ltd
Post by ratmonster »
I realize that this might qualify as a thread ressurection, since this one hasnt been active in over a month, but I had to comment on it. Just had to.
I have thought for some years now that the 3.8 F-body setup is way under utilized! I think your idea for the truck is great. These engines arent horsepower monsters, but they beat a 2.2 all to heck and back again, and seem way more efficient than the 4.3, as previously mentioned. They are a reasonable space-saving design as well, which means they could be shoehorned into many an engine bay. I have seen a number of smaller cars have 350 motors crammed under the hood for show or racing purposes, which is awesome, but I want a car I can drive daily. A Chevette with the 3800 would be double the horsepower, a great daily driver, and still a WICKED sleeper at the red light (although I do not condone street racing, who doesnt want to at least smoke their tires and give the guy in the Honda Civic a mild heart attack?). I'm goona spend some time online looking for 3800 swaps just to see what others have done. You, sir, are inspiring!
haro1225
Post by haro1225 »
ratmonster wrote:I realize that this might qualify as a thread ressurection, since this one hasnt been active in over a month, but I had to comment on it. Just had to.
Just about a year over a month :wink:
Wes, did you ever make any progress on this?
-Ryan
