HVAC air flow problem
strongt3310
Year and Trim: 2001 SE
Post by strongt3310 »
I've got a 2001 SE with a low air flow problem coming out of any of the vents. Be it floor, vent, or defrost settings. The mode actuator is moving for the different settings. As is the actuator for the temp control. Cabin filter is new.
I do get slightly better airflow in the cold setting then in heat. The blower motor is working good but I just can't get any air flow. Any ideas ?
2001 SE 98,000 Miles
xcbullet
Year and Trim: 2000 SE, transg kit & B&M trans cooler
Re: HVAC air flow problem
Post by xcbullet »
Dirt in air unit. Mine is weak & not sure how to clean it with out taking it apart. Maybe some one else knows how to get to it on here.
strongt3310
I was hoping it was something else. Funny if it is dirt. The old owner of the car had a cabin filter installed. Funny much dirty would get past it.
