2002 ssei spark plugs?
I just replaced the spark plugs on my ssei 2 days ago. The car was used with 181000 on it. I bought it for a winter driver. I found that 5 plugs had autolite 606 in it with gaps at .065-.070. It had 1 AC Delco in it.rust around all of the plugs. I put NGK TR6 back in.the came gapped at .035. I gapped them out to .055. I bought the TR6 for future mods(3.4pulley, tune,180stat down pipe) . My question is that until I put the other mods on is the .055 the correct gap moor running stock. I just have a k&n drop in.
- nos4blood70
- Year and Trim: 2003 SLE
Re: 2002 ssei spark plugs?
.55 is perfect.
pittydaddy
- Year and Trim: 2000 Bonneville ssei series 2
.55 is good. Make sure you use ac delco iridium. Kills me. Fords love motorcraft chevy loves ac delco. Regardless of the after market quality. They always seem to run better with OE parts
- xxdabroxx
- GXP Member
- Year and Trim: 2001 Bonneville SSEI 32,000 miles bone stock
The plugs I took off of mine were NGK's pretty sure they are factory too with only having 38k on the car.
xcbullet
- SSEi Member
- Year and Trim: 2000 SE, transg kit & B&M trans cooler
2000 regal SC I had came from factory with ngk. Think that's what I'm going to go with from now on. Last AC I got had ngk on the metal.
- xxdabroxx
- GXP Member
I put the autolites that Intense sent me but I have never been an autolite fan. Not sure how long they will live in there before they get swapped, but I'm also not know to change spark plugs with very much frequency.
Ran NGK Coppers for a while.. the gap kept opening up and made the car miss. swapped back to OEM Delco Irridium and good to go. NGK are good plugs, not had good luck with Coppers and boost. I have had Irridiums for a while now and doing great, used NGK Platinums in my Monte Z34 Turbo and allways ran great.
Delco or NGK are great plugs, i like Irridiums on the L67's.
S
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
