What Brand Tie Rods Would You Use?
Posted: Sat Dec 06, 2014 8:01 am
by Blown93SSEi
I'm in the need to replace my Tie rods and wondering what brand you would use to replace them with.
Factor in purchasing only from either Rockauto or Advance Auto Parts.
Moog is what I hear is the best, But I've heard they've cheapened their product out lately.
Re: What Brand Tie Rods Would You Use?
Posted: Sat Dec 06, 2014 8:43 am
by SuperHbody
I'd say if not AC Delco, than definitely MOOG. Haven't heard at all that MOOG is cheapening there product, still a safe bet.
Posted: Sat Dec 06, 2014 11:34 am
by MattStrike
Moog "Problem Solvers", there is a cheaper line of Moog parts, you want the problem solvers.
Posted: Sun Dec 07, 2014 8:28 pm
by Zeik75
:withstupid: Haven't had a problem with any moog part i have used.
Posted: Sun Dec 07, 2014 8:48 pm
by repinS
The Problem Solver line is usually pretty heavy duty. In some cases, even better than OE to address common failure points.
Their R-Line is the cheapo stuff. Avoid that.
Posted: Tue Dec 09, 2014 12:16 pm
by buickman104
I used Moog problem solvers to replace my inner and outer tie rods. Moog came out with a cheaper line of Moog call R-line (R for ricers) and those are the chepo ones. Just make sure you aren't getting the Moog R line garabage and you should be good.
Posted: Tue Dec 09, 2014 7:39 pm
by Jrs3800
repinS wrote:The Problem Solver line is usually pretty heavy duty. In some cases, even better than OE to address common failure points.
I agree.. I have 100K on my Moog Problem solver tie rod ends, replaced them with the Rack & Pinion..
So the AC Delco( get the expensive one ) or the Moog Problem Solver...
Posted: Tue Dec 09, 2014 8:51 pm
by repinS
^ Important on the AC Delco. Their "Advantage" line is the same idea as the Moog R-Line. Low-end and built to be cheap, not built to last.
