Dome Lights not working!
Posted: Mon Oct 27, 2014 12:50 am
by OnlyAnSE
My interior dome lights went out a couple of days ago so I figured fuse right? Well today I found the fuse that was broken amd replaced it. Everything was fine, until tonight when I was driving home and when I parked and pulled the key out there was no light again! What is causing these fuses to blow so rapidly? Any help is appreciated thanks!
Re: Dome Lights not working!
Posted: Mon Oct 27, 2014 1:29 am
by 1oldman
Check to see if the correct size fuse is installed. If it is the correct size, then something is drawing more power than it should. You'll have to get an electrical schematic to know all the items on that circuit, then unplug them one by one. - BC
Posted: Mon Oct 27, 2014 3:30 am
by Jnegrea93
There could also be a broken wire touching another part of the car
