2002 Grand Prix crank balance gone wrong? (pics inside)
Posted: Sat Sep 13, 2014 4:53 pm
by crzydmnd72
Re: 2002 Grand Prix crank balance gone wrong? (pics inside)
Posted: Sat Sep 13, 2014 10:04 pm
by crash93ssei
Wouldn't this be part of the reason for the balance shaft?
Posted: Sun Sep 14, 2014 12:16 am
by 95naSTA
The engine's rotating assembly is balanced by the weights in the harmonic balancer, flex plate, and crank counter weights.
The harmonic balancer is meant to cancel out firing order vibes created from using a 120* firing order in a 90* v6.
Posted: Mon Sep 15, 2014 12:29 am
by MattStrike
In order to balance the rotating assembly the machinist needs to have the harmonic balancer, the flexplate, at least one full piston and rod assembled, bearings, rings, bolts and the crank. Yes he would have to take out a lot of material from the crank to offset a small change on the piston. Worst case, you could have another shop check his work. Also note that engines are not 'zero balanced' from the factory. They are balanced just enough to run smooth in the normal operating range.
The balance shaft cancels out 3rd order harmonics associated with the 90 degree V6 at idle and low RPM cruising (due to the natural imbalance of having two pistons traveling up on one bank and only one on the other).
Here's a good read:
http://www.carcraft.com/howto/ccrp_0803 ... balancing/
Posted: Thu Sep 18, 2014 6:09 pm
by crzydmnd72
Thats great info Matt and I was hoping you would chime in. He had all 6 pistons, rods, rings, bearings, bolts,, flexplate and HB. Thats interesting that they are not zero balanced from the factory also. By drilling the really thin weights, has that weakened anything?
