New Alternator?
- OnlyAnSE
- Year and Trim: 2001 Bonneville SE
New Alternator?
Im guessing this an alternator going bad but the problems im having are whenever i am just sitting in park my volt meter will go up and down from 12 to 15-16. Also whenever i listen to my music with my subs going I get extreme dimming whenever the bass hits a certain frequencies(mostly low),running a 1200 watt amp to 2 12's. If anyone thinks that there is something else going on or anything to add please let me know before i waste money on a new alternator! Thanks Much!
Morgan
04 gxp bone stock internals. Touchscreen dash with heavily upgraded sounds system.
- nos4blood70
- Year and Trim: 2003 SLE
Re: New Alternator?
Make sure the leads are tight on the battery.
- OnlyAnSE
Re: New Alternator?
Just solved it! The positive terminal connecting the positive lead and subwoofer lead was a tad loose from the lack of room for tightness from the sub lead.will be looking into a new positive lead also since the one that is one there is a bit corroded and deformed. Thanks for your opinion it saved me from making a big mistake!
Morgan
- bobgto65
- Posts like an L36
- Year and Trim: 2002 SSEi
2004 Bonneville GXP - Location: Maryland
Re: New Alternator?
Connect the positive wire to the sub to the positive wire on the rear fuse block. The bolt is long enough for you to terminate the wire with a ring terminal that fits over the bolt and under the nut.
bobgto65
