anyone with experience doing a cat delete ssei
Jbro238
Year and Trim: 2002 ssei
Post by Jbro238 »
im looking at doing a cat delete for my 02 ssei. anyone with experience doing this have any tips or tricks? i really will be figuring it all out by doing it as i really dont know how. also will it change the tone of my exhaust (im sure it will but in what way) just curious
any and all comments appreciated
Jake
*** Certified Adrenaline Junkie ***
2002 white SSEI Bonneville.
INTENSE FWI
Many beginner level performance mods to come
3 10" Championship series pioneer subs in the trunk.
AJT2004
Re: anyone with experience doing a cat delete ssei
Post by AJT2004 »
How will you pass your state's inspection? In New York your car would not pass without a cat.
SuperHbody
Year and Trim: 1988 LE
Post by SuperHbody »
Modern cars are tuned with CATS so well that any attempt to remove them will impact performance negatively. You won't gain anything unless your going all out race car. Keep them on and concentrate on other areas.
Jbro238
Post by Jbro238 »
Kansas does not have emissions enforcements for motor vehicles.
And it does make sense that removing the cat would only increase airflow. So I'm not so sure. I would get increased horsepower. I don't see how it could impact negavitely
INTENSE FWI
You can gut the cat. You will be getting a code though, which means you will have to get a tune to get rid of it.
Jbro238
Post by Jbro238 »
I could do an o2 spoof
It would get rid of the code without a tune for the PCM
INTENSE FWI
It will sound horrible and you will regret it.
flatlander745
Post by flatlander745 »
Get a magnaflow universal weld in high flow cat for under $100 Or a down pipe/ high flow cat assembly from ZZPerformance for just under $200
I would get the combo.
http://shop.zzperformance.com/store/p/3 ... npipe.aspx
2000 SSEi Galaxy Silver with New TEP Trans, A 62,000 mile engine out of grandma's car, all new front and rear suspension KYB/ Energy Suspension.
[url][URL=http://s871.photobucket.com/user/flatlander745/media/image-5.jpg.html][IMG]http://i871.photobucket.com/albums/ab278/flatlander745/image-5.jpg[/IMG][/URL][/url]
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
removing the cat will change the sound of the exhaust. If you have a resonator and mufflers still in there it will sound a little louder. My suggestion is if you are going to gut the cat then just get a offroad downpipe without a cat from ZZP. it will give you more performance, fuel economy and sound and you can always put it back in and sell the offroad pipe.
Pro's of Removing the cat:
* More sound
* "Better Flow" for better performance (In theory... the stock cat will not restrict enough to notice any power difference, the downpipe is the part that robs power from the entire system.)
Cons of removing the cat:
* Fuel smell in exhaust fumes
* Check engine light (without O2 SIM or Tune)
* O2 Sim failure causing CEL (Best to tune it out in the ECU)
* Sound may not be to your liking (Hollow chamber could cause popping/gurgling in exhaust)
Replacing the DP with a ZZP catted downpipe:
* All of the Pros's with none of the Cons.
Stock vs ZZP
Shane "RedZMonte"
2004 Z16 Z06: Virgin
Jbro238
Post by Jbro238 »
all really good information. how hard would installing that downpipe with cat be. im liking that option a whole lot. what kind of gains will i get power-wise?
you all have convinced me top stray away from a complete cat delete
INTENSE FWI
