wobble while driving
00Bonneville00
- LE Member
- Year and Trim: 2000 pontiac Bonneville ssei
00 Bonneville ssei wants to wobble while driving hubs good no play worse wh3n turning especially right any ideas what this is
- bobgto65
- Posts like an L36
- Year and Trim: 2002 SSEi
2004 Bonneville GXP - Location: Maryland
Re: wobble while driving
Possibly a bad CV joint?
bobgto65
Or ball joint.
- 1tinindian
- Posts like an LG3
- Year and Trim: 2004 SLE Premier Edition
2005 GXP - Location: Rockford, Iowa
Bad tires can cause this.
DJC906
- SSEi Member
- Year and Trim: 1998 Oldsmobile Aurora
I have a horrible wobble in my car too, although it is an Aurora i thought i would chime in with what i already replaced.
I got new lower control arms, ball joints, inner tie rods and outer tie rod ends, sway bar end links and new tires on the front. Was told my CV axles were bad so that is my next step as well as wheel hub assemblies.
The wobble i describe is not a little vibration, its a dangerous type wobble if that makes sense. And no im not driving it at the moment. Just thought i would chime in incase your wobble is severe like mine, so maybe you could rule out the parts i listed.
- techweenie
- SSE Member
- Year and Trim: 2004 GXP
Check the subframe mounting bolts. One of my ex's had a lesabre and those went bad. Holy hell talk about a scary car to drive. The whole subframe shifted under the car in turns and threw off steering angles and just all around made it very unpleasant to drive. Most of the repair parts can be sourced from a junkyard. Mounts are identical between lots of models.
2004 Bonneville GXP Greystone Metallic - all stock
2002 S10 ZR2 - my favorite truck in the world
1998 K3500 CCLB - motor rebuild in progress, future mud truck
1994 S10 Blazer - 5" lift, narrowed ZR2 rear end, 32x11.5 tires, parting out due to overwhelming rust
