1998 SLE with bad front wheel bearing
jkchapman
Year and Trim: 98 SLE 325K (Still goin strong)
00 SLE 165K
Post by jkchapman »
I found the thread on replacing a wheel bearing on a 1998 SLE (thanks for the post BTW) HOWEVER one point wasnt covered in the thread I was reading.. Once I change out the bearing will I have to take the car into the shop and the wheels realigned ?
J Wikoff
Re: 1998 SLE with bad front wheel bearing
Post by J Wikoff »
Unless you unbolted the knuckle from the strut for so e reason, you shouldn't have to.
98SSE
Year and Trim: 2001 SSEI/2007 TBSS/2004 CTS-V
Post by 98SSE »
J Wikoff wrote:Unless you unbolted the knuckle from the strut for so e reason, you shouldn't have to.
This. You take off your caliper/rotor then should be able to access the 3 star pattern bolts. Once you break the axle nut loose and take the 3 bolts out it should come right out, unplug the abs/wheel sensor. Reverse order for installation.
"Big 3", Tint
CatmanFS
Year and Trim: Gold 98 SSEi
Post by CatmanFS »
Let me know if replacing them makes a big difference.
zigger21
Year and Trim: 1997 Bonneville SSE
2005 Bonneville GPX
Post by zigger21 »
jkchapman wrote:I found the thread on replacing a wheel bearing on a 1998 SLE (thanks for the post BTW) HOWEVER one point wasnt covered in the thread I was reading.. Once I change out the bearing will I have to take the car into the shop and the wheels realigned ?
You shouldn't need to have it realigned I replaced 4 wheel bearings on a 1992 Bonneville a 2004 Yukon Xl Denali, 1998 Bonneville and a 2002 Pontiac camaro and no alignment issues were found with the laser aligner.
KM AXer
Year and Trim: 1993 SSE Medium Garnet Red Metallic, Gray
Post by KM AXer »
Have never seen a "Pontiac camaro"... Must be a rare car! :)
(just funning, no offense intended)
Alan Sheidler
Proud Third Caretaker of the Family Heirloom '93 SSE
Medium Garnet Red Metallic, Gray Leather Interior
Silver Cross-Lace Wheels (I love this car)
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
No alignment needed, I can do a 92-99 wheel bearing in my sleep due to my cheapness and buying crappy ones. That being said, make sure you get a Timken or equivalent, never a parts store house brand.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
