Alright, so Tuesday I'm going to start tearing into the LeSabre to do the valve cover gaskets, upper intake, oil pan, etc. I'm going to be painting the valve covers and the intake manifold with a blue/silver color scheme. I'll probably paint the FWI to match as well.
Is there anything specific I should do before I paint the parts as far as prep work? I"m going to clean them super good first with brake cleaner, and then wash them with soap and water to make sure all the cleaner is off, but is there anything else I should do?
Also, I'd really like to paint the fuel rail to match. Is there anything special I need to do to paint it? I'm going to be using just standard high heat engine paint from Advance, and I need to still pick up a can of primer as well since they were sold out (unless that's not needed with the engine paint?).
Painting/prepping engine parts
- Jfridge92
- Posts like an L67
- Year and Trim: 1999 Buick Lesabre Custom
Joseph
1999 Infiniti G20T - Sold
- FasGP
- GXP Member
- Year and Trim: Pullied Clean 2k Black SSEi...
Re: Painting/prepping engine parts
Clean and prep makes all the difference. If its high wear items, I even use a quick dry primer under it.
I usually use acetone to clean, as it is quick evaporator and very powerful for prepping. Rarely ever had issues. On engine parts, I will often use a heat gun to bake in each coat...speeding up the drying process as well.
