2000 SSEi - hub assembly replacement - stripped hub bolts
Posted: Sat Apr 26, 2014 10:27 pm
hi guys,
Have had Service Stability System message and traced it down to front passenger side hub.
Bought a Timken hub that meets spec on this site.
Have taken off the wheel, rotor, caliper and brakes.
Started removing hub bolts and they are stripping out.
Sprayed deep creep on them and let them soak for 5 hours.
Still no joy.
Used a Bolt out...rounded off the head even more.
Concerned about the top one and the one at 8 o'clock.
Top one won't come out either.
Tried the one at 8 o'clock but its not budging either.
Any ideas what to do next?
Thought about cutting the existing hub apart with a sawzall or a portaband saw if I can make it work.
Not sure that is the best approach.
Looking for guidance about what to do next or your thoughts on cutting the hub apart with one of the above tools or a angle grinder.
Got to get this fixed as it is my wife's daily driver.
Didn't figure I'd have so much trouble with 13mm bolts.
Thanks so much for your help.
Still no joy.
