HID kit question
Posted: Wed Apr 02, 2014 11:25 am
by haro1225
I am going to get the DDM kit and using the mini H1 projectors, so I'll get the H1 kit. Is there some kind of adapter needed so that it plugs into the 9006 plug?
Re: HID kit question
Posted: Wed Apr 02, 2014 11:49 am
by nos4blood70
The harness should have a female 9006 connector to get signal.
*EDIT* Meant female!
Posted: Wed Apr 02, 2014 11:51 am
by haro1225
Ok sweet, I'll be ordering this stuff probably Friday. Then the hard part will start.
Posted: Wed Apr 02, 2014 11:55 am
by nos4blood70
Glad you decided to go with the Mini H1. You're gonna love it. Retrofits are worth every hour you put into them!
Posted: Wed Apr 02, 2014 3:02 pm
by MurderMitten
literally got my DDM kit today. I got the 6000K bulbs with the harness. didnt get the 9006 adapter and I have everything I need. Also. Im guessing the wire with the fuse is power and the one without is ground? Then plugging it into your factory harness makes it turn on when the car tells it to? This kit is not labeled and has no instructions
Posted: Wed Apr 02, 2014 3:15 pm
by haro1225
That's pretty much how it works, I'm currently running a relay harness with my 9012's.
How long did it take to get the DDM kit anyways?
Posted: Wed Apr 02, 2014 4:22 pm
by MattStrike
Not sure how the DDM kit is, but there should be a dedicated power and ground wire, a set of relays, and the trigger for the relay that uses the OEM headlamp connector. The ballasts are powered through the dedicated power and ground, not off the the OE harness.
Posted: Wed Apr 02, 2014 5:32 pm
by CMNTMXR57
haro1225 wrote:That's pretty much how it works, I'm currently running a relay harness with my 9012's.
At least 2 weeks if you didn't do any form of expedited shipping. This is my one beef with them as the sh*t has to come from China.
Posted: Wed Apr 02, 2014 6:14 pm
by MurderMitten
They don't offer expedited shipping. Ordered it on the 18th of march. Shipped on the 20th. Got here today
Posted: Fri Apr 04, 2014 2:31 pm
by haro1225
Just placed the order. Now to figure out how to get the reflector of the headlight housing.
Posted: Tue Apr 15, 2014 8:21 pm
by haro1225
Got the bulbs today so I'm going to be starting this. There is 2 wires on the projectors, are those supposed to be for the high beams?
Posted: Tue Apr 15, 2014 8:35 pm
by corvettecrazy
I miss my projector retro fit. RX330 projectors with Philips bulbs and RX330 ballasts.
At least they live on in Bill's car.
Posted: Tue Apr 15, 2014 9:41 pm
by MurderMitten
On the projector housing? or the bulb? The two on the housing should be if you got Bi-xenon projectors that would trigger the blocker in the lenses to unleash the full power of the projectors
Posted: Tue Apr 15, 2014 10:09 pm
by haro1225
The ones on the housing. I probably won't hook them up though.
Posted: Tue Apr 15, 2014 10:36 pm
by corvettecrazy
haro1225 wrote:The ones on the housing. I probably won't hook them up though.
If they are for solenoid for the bi-xenon model, just tap them to your high beams. You wont regret it.
Posted: Sun Apr 20, 2014 10:44 pm
by haro1225
I'm getting very close to having this done. What amp fuse are you guys running on the relay harness?
Posted: Mon Apr 21, 2014 7:41 am
by MurderMitten
Did you order the relay kit? I used the fuse that was included in the kit.
Posted: Mon Apr 21, 2014 7:44 am
by haro1225
I had one already but the fuse had popped a while ago so I had the 9012's just with the stock wiring and I forgot which one it was.
Posted: Thu Apr 24, 2014 10:01 pm
by haro1225
Ok, I have these installed and everything, but now when I turn them on, only the right side comes on, and then sometimes only the left. But also they both turn on if I go on-off a couple times. Could this be crappy ballasts?
Posted: Fri Apr 25, 2014 12:33 am
by nos4blood70
Which ballasts do you have? If they are the SS ballasts there is a recall on them. You *should* have DSPs. If that's the case, I'd recheck your grounds and make sure they are clean.
