New to site and a lot of great info here . I have no display and the controls also doesn't seem to have any power . So I don't see a fuse for HUD is this a common issue? If not any idea on where to start?
Thanks in advanced
2000 SSEI HUD
Bmiller269
- LE Member
- Year and Trim: 2000 SSEI gray leather
Re: 2000 SSEI HUD
Did you look in the fuse-box under the backseat lower cushion? I haven't dealt with this issue before, so that's about the extent of my knowledge, lol.
Bmiller269
- LE Member
Re: 2000 SSEI HUD
I've checked both boxes engine bay and under seat. And all fuses checked good. Thinking it may be the switch.
- harofreak00
Re: 2000 SSEI HUD
The HUD module receives battery positive voltage from the rear fuse block.
The HUD module receives ignition positive voltage (IGN3) from the rear fuse block. (Fuse #34)
Bmiller269
- LE Member
Re: 2000 SSEI HUD
Got it and it's working now. On to the next bug in this car. Will be a nice ride once I get thru all of them. Thanks for the help guys.
- harofreak00
Re: 2000 SSEI HUD
Was it the fuse?
Bmiller269
- LE Member
Re: 2000 SSEI HUD
Connection on the switch, and then was adjusted way low so after I gotta a glimples of it. Got it adjusted and all's good now there.
Re: 2000 SSEI HUD
I drove mine for a year before I figured out that the HUD worked just fine; it was just adjusted so far down that I couldn't see it at all. So for future reference, check that first.
