Common issue?
BeeVeeSE1998
Year and Trim: 1998 SE
Common issue?
Post by BeeVeeSE1998 »
I'm in need of help with my head unit. It works great and has the equalizer and the cassette player on it. The problem, is that when I turn the radio up, it turns the volume down. And when I turn it down, it still turns down! This is solved by VERY slowly turning the knob to get it to do what you want. But, for obvious reasons this is annoying. I had a friend with a Gran Prix that did the exact same thing. By the way, the vehicle is a 1998 Bonneville SE. Any idea if this is common? If so, how do I fix it?
1998 Pontiac Bonneville "GMac" SE
DaMaroon
Year and Trim: 2003 SE
Re: Common issue?
Post by DaMaroon »
Haven't tried this but it sounds about right. It's what I'd try for an erratic pot. Haven't taken an encoder apart, yet.
http://www.grandamgt.com/forum/showthread.php?t=90243
BeeVeeSE1998
Re: Common issue?
Alright. Thanks! That helps a lot.
